Go to Post "Field orientation is like a homing pidgeon that can fly backwards." - LostWolf [more]
Unread 19-06-2006, 14:57
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Adding Bluetooth to Vex
Originally Posted by Vex13
3) If you already have the desired behavior occuring between the pc and micro via a thethered link, add a bluetooth link between the pc and programming dongle should be pretty much plug and play (add the module and pc dongle, set up the link, adn we're set). Right? Or am I being too naive here?
I think that this means you are using an RS-232 port on the VEX side and on the PC side. So you are close to being able to just replace the cable with 2 AirCables or BrandX radios, but you are not completely sure of success.
It depends on if the PC/VEX link are using other RS-232 signals for timing etc. For example they could be using anotehr wire for flow control or timing. This may or may not work, depending on the signals you need the radios to duplicate and how critical the timing is.
Even if you are only using 3 wires (TX, RX & GND), you are still not home free. We have had cases were we can get a boot loader to work via a cable and had no success downloading code via a Bluetooth radio set. We think this is due to some critical timing issues but we are not 100% sure of the reason for failure. We do know that Bluetooth is pretty good at making sure that data sent on one end gets to the other side, but it is not so good at meeting critical timing issues.
Good Luck.
Joe J.
Team #88, TJ2
how to build a VEX programming module bblack7489 FIRST Tech Challenge 78 09-06-2011 16:03
Useful VEX Tools Joe Johnson FIRST Tech Challenge 4 26-04-2005 18:48
Vex Robotics Vex FIRST Tech Challenge 0 14-04-2005 13:48
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
VEX Kits ARRIVED!!! Joe Johnson FIRST Tech Challenge 14 28-03-2005 19:28
