Go to Post Darn IFI and AndyMark for making quality products! :) - Gabe [more]
Unread 20-06-2006, 11:22
Jake Lewis's Avatar
Jake Lewis Jake Lewis is offline
Co-Team Lead
FRC #0537 (Charger Robotics)
Jake Lewis is an unknown quantity at this point
Send a message via AIM to Jake Lewis
Vex Tank Tread Screw Problems
We've been trying to make the Vex tank treads work, and we've run into a problems. The one-inch screws seem to be too short to extend all the way through the mounting holes on the bogey wheels and still go through a metal plate and a nut, even though this is what the instructions show to do. Has anyone else had this problem, or do we have defective kits, or are we just missing something obvious?
Jake Lewis
Co-Lead, Team 537
jakisnaki@hotmail.com
Unread 20-06-2006, 11:29
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Vex Tank Tread Screw Problems
These bogey wheels have a counter-bore on one side, they are not symetric. It is likely you have just installed them backwards. Try reversing them, and see if the screws will work now.
JV
Unread 20-06-2006, 11:31
Jake Lewis's Avatar
Co-Team Lead
Our 4-wheel bogey wheels do not have counter-bores. The two-wheeled assemblies do, but even with those, the screws do not work. We have two tread kits, and the wheels are the same in both.
Jake Lewis
Co-Lead, Team 537
Unread 20-06-2006, 12:01
JVN JVN is offline
@JohnVNeun
I'm fairly positive you're installing them backwards.
I just opened a brand-new tank-tread kit, and double-checked that everything works, and that the screw-lengths are correct.
See attached pictures for correct mounting configurations.
JV
ID:	4465  Click image for larger version
Unread 27-06-2006, 18:23
Gratz Gratz is offline
FTC #0537
Gratz is an unknown quantity at this point
We got it figured out. The kit was missing the screws and no one actually checked to see if the ones that we had were an inch long.
Tank Tread Wheel Joe_Widen Technical Discussion 8 29-05-2006 23:28
Tank Tread Stair Climber 114gopher Technical Discussion 9 12-12-2005 21:41
Tank Tread suppliers? Rombus Technical Discussion 2 22-02-2005 11:01
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
