Go to Post Begging, yelling, kicking, and screaming for members of my team to send me updates while I'm at college not doing homework. - Ginger Power [more]
Unread 06-06-2006, 18:18
cprogrammer's Avatar
cprogrammer cprogrammer is offline
FRC #1595 (Gremlins)
cprogrammer will become famous soon enoughcprogrammer will become famous soon enough
Gyro/Camera Combination Code Problems
I have combined the gyro and the camera code that will run on the 2006 FRC controller. I tried it out and everything runs perfectly except the FRC will periodically and randomly reset or disable itself. Is this just a registry overflow or is it something else. If anybody has any information on this please give me some feedback.
Unread 06-06-2006, 18:43
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Gyro/Camera Combination Code Problems
Is it possible this is from the silicon bugs in the PIC18F8722? Are you using new firmware/libraries?
Unread 21-06-2006, 11:01
I am just using the firmware that came with the 2006 system.
Unread 21-06-2006, 13:12
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
This behavior is similar to what we see when too many interrupts are being generated. The processor ends up getting swamped.
If you can run the gyro with the camera unplugged or the camera with the gyro disabled, that could be the case.
Eric
Don't PANIC!
S. P. A. M.
Unread 21-06-2006, 21:45
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Hmm, we got it to work fine, I don't know.
I thought there was a problem mentioned before that you must combine one into the other (it only works one way, like gyro put into camera works, but camera put into gyro doesn't). I believe if you didn't do it right it was completely unusable though, so that's probably not it.
If you're getting overflows, maybe turning down the sample rate on the gyro could help.
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Gyro Code Problems railerobotics Programming 8 27-01-2006 10:45
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
