Go to Post We never play to lose, or even go easy. We play our best every match. - Paul H [more]
Unread 21-06-2006, 18:17
CraigHickman
Posts: n/a
pic: Coaxial Swerve drive, lightened.
Unread 21-06-2006, 18:24
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Re: pic: Coaxial Swerve drive, lightened.
That looks super cool. Instead of all that machining to make it lighter, you could try just using a thinner plate, such as 1/8'' or 3/16" (it looks like you have 1/4''). You can never have to many speed holes though.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 21-06-2006, 18:25
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
allot of sharp edges i see. this thing is awfully tall. you know how much side load those bushings are taking and how much shear that creates between those plates up there? i know modules that i make out of legos that are that tall don't last long. it would be nice if it were supported closer to the Axel.
Unread 21-06-2006, 18:54
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I've been curious as to why you've opted to mill pockets into the plates rather than entirely cut out large sections. Any insight?
--Madison--
...down at the Ozdust!
Unread 21-06-2006, 19:30
CraigHickman
Posts: n/a
The reasons for the lightening style is structure. As a whole, the entire module is only 8 inches tall, from the top of the power transmission shaft to the bottom of the tread.
The plates used are 1/4", and it can't be any thinner, as it's held together with bolts. As for sideload issues, Inventor 11's stress analysis tells me that it can take about 900 pounds of sideload as a whole, which just might be enough for a FIRST bot.
Unread 21-06-2006, 20:40
Joe_Widen's Avatar
You could try using Al tubing and be crafty with the cnc mill. It would have zero bolts (...gasp....). Thats how im designing mine atleast. No fancy stuff, no coaxial, just plain old spur gears and motor mounted on each module. Fancy gears are not my friend, especially after using worm gears (a thousand and one to many headaches there), although, I think helical gears are crazy cool. Good Luck to ya.
Unread 21-06-2006, 21:55
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Maintinence would be a pain though, even more so w/ the extra stuff due to the coaxial design
Unread 21-06-2006, 22:04
CraigHickman
Posts: n/a
The gear sytem for said module is a set of bevel gears (under martin sprocket as miter gears.) They give me a 1:1 ratio, which matches all of the ratios in the module. This is to make calculations for the gearboxes (maybe 2 speed?) which are elsewhere on the robot.
Unread 21-06-2006, 22:59
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
I would recommend you re-evaluate you 1/4" plate idea....1/8" bent sheet metal is more than capable.....
Unread 21-06-2006, 23:58
REVving up for a new season
FRC #2848 (All-sparks)
This quote scares me a bit. I just want to warn you and everyone else about integrated FEA in software, especially inventor. FEA is good when you have an idea about how strong something is and you just want a verification. ie. you have already calculated an approximation using a number of other methods, or you are familiar with your mechanical properties of the materials and their metal working abilities. IT is NOT OK just to click a couple buttons and assume that the number that it gives you is what you are going to get. First of all nothing that is build comes out exactly like the cad model, no matter how good your machining abilities are. Next there are a number of mistakes that can exist in a cad model from small keystroke errors or incorrect constraints.
I am not trying to come down on you i am just trying to warn people that if you blindly trust a number that the computer gives you without understanding what it is calculating you have the possibility of large errors, which could be catastrophic in your machine.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 22-06-2006, 00:14
Nuttyman54's Avatar
Mentor, Tactician
i'm not familiar w/ the stress analysis tools in Inventor, but you might want to check that it's not just telling you that if you apply uniform pressure along all lateral surfaces you can survive up to 900 lbs before deforming. Looking at weak points, i'd be VERRRY surprised if it could take 900 lbs at the joint.
EDIT: Thought of another thing: are you treating this as one solid object? It occurred to me that the bolts might sheer off before you reach that 900 lb limit....
Unread 22-06-2006, 01:53
CraigHickman
Posts: n/a
I believe I did something wrong in the stress test... not sure what yet... I'll let y'all know when I find out where I messed up...
Unread 22-06-2006, 03:20
DB_UPS's Avatar
DB_UPS DB_UPS is offline
tool or die that is the question?
AKA: Ryan Quinlan
FRC #1675 (The Ultimate Prtoection Squad)
DB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura about
Send a message via AIM to DB_UPS
The bent sheet metal looks easy to make and harder to screw up. Joe, you should look in to make a version this way too. So if swerve drive is a optional next year we have two ways to make it. But i do like the milling way too.
Unread 22-06-2006, 03:54
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Sheetmetal is only easier if you have the resources to precisely punch and bend it. Otherwise it's a disaster waiting to happen.
2001-2004: Team 100
2006-Present: Team 254
Unread 22-06-2006, 09:11
BSEE, MSEE, JD
AKA: employed
You don't have to use a punch....you could get it done by a waterjet or laser just as easy....
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
Swerve Drive on a Jeep Karthik Math and Science 3 01-02-2005 17:50
pic: Coaxial Lego Crab drive CD47-Bot Robot Showcase 11 04-11-2003 14:45
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
