Go to Post If Teflon-coated pans have a no-stick surface, then how to they get the Teflon to stick to the pans? - dlavery [more]
Unread 22-06-2006, 00:14
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: pic: Coaxial Swerve drive, lightened.
i'm not familiar w/ the stress analysis tools in Inventor, but you might want to check that it's not just telling you that if you apply uniform pressure along all lateral surfaces you can survive up to 900 lbs before deforming. Looking at weak points, i'd be VERRRY surprised if it could take 900 lbs at the joint.
EDIT: Thought of another thing: are you treating this as one solid object? It occurred to me that the bolts might sheer off before you reach that 900 lb limit....
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
Swerve Drive on a Jeep Karthik Math and Science 3 01-02-2005 17:50
pic: Coaxial Lego Crab drive CD47-Bot Robot Showcase 11 04-11-2003 14:45
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
