Go to Post CD has a vast store of knowledge, information, and wisdom. Add to it. - JaneYoung [more]
Unread 22-06-2006, 18:33
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Sharing motor(s) tranmissions in Swerve drive
For some background on our team's first ever summer prototype work read this thread.
What I am posting here is a request for what you think would be the pros and cons of having a single motor and transmission per side of a crab-steer drive system. (What is a side in a swerve system?) Consider having a single transmission with one or two motors being shared with two modules per side. Front/Rear or Left/Right. Add to that the concept of also steering modules in the same pairs. I'd like to reference a white paper by team 79 Krunch for info on steering options in swerve drives.
Anyhow,
Post your thoughts
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 22-06-2006, 19:42
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Sharing motor(s) tranmissions in Swerve drive
With regard to driving them together, it's feasible, but be aware that you'll limit yourself a little bit in the area of complex motions (because you can't get all 4 wheels spinning at different speeds). This probably won't be too big a deal, though, because it's difficult to control that sort of motion by hand. In autonomous mode, it might limit your options a little, but you should be able to work around it.
Also, if you steer them together, you're limiting yourself (under most circumstances) to either a lot of sliding, or to translations only. As long as you're happy with a skid-steer component to some of your turns, this is quite possible. In fact, most robots forego the ability to steer modules independently, because they'd rather use the motors elsewhere, and don't really need fancy rotational moves (like orbiting an object while revolving around the robot's own axis).
I'm trying to remember if 47's 2002 robot had 4 independently-driven and independently-steered modules; I think that it did, and that would make it one of the very few with that capability.
Unread 22-06-2006, 20:40
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Their 2001 robot had this capability, and I believe it is the only FIRST robot to ever do so.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 22-06-2006, 21:12
2002 being the one with the mini-treads, and 2001 being the one with the fancy ball-holding arm. To be honest, I thought the 2002 could do this too, but it's been so long, that I don't remember.
Last edited by Tristan Lall : 22-06-2006 at 21:28. Reason: I was going to post some pictures, but realized that I wasn't sure about the robots that I'd identified....
Unread 22-06-2006, 21:40
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
actually, 2001 had the mini-treads to help it ride over the mid-field 2x4. i still can't believe that they got the whole thing to fit under the bar.
[edit] pics can be found here and here [/edit]
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 22-06-2006, 22:01
That explains it. I was off by a year. Oops. Also, the 2000 robot didn't have the 4 driven and steerable wheels...that makes sense now.
Unread 23-06-2006, 00:32
[/edit]
From 1998 to 2002, Team 47 had some of the most awe-inspiring robots that I have ever seen. Each year they'd make your jaw drop. It seemed like there was no limit to what they could accomplish. They managed to pack loads of functionality into simple and elegant designs.
Unread 24-06-2006, 09:14
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Thanks for the compliments guys.
Our team used "Swerve" drive systems for several years. Some independant (all 4 wheels) configurations and a - Four Wheel configuration moved by a single motor. All had their good and bad points. The nature of the game in recent years has made swerve drives to be shelved in place of powererful fast systems that can climb.
Due to resources required both mechanical and physical the need for swerve has been very low as it would impact the game very little. I see an opening for FIRST to have a game that will require the felexability of a swerve drive system.
Swerve is many times confused with a steerable chassis (like a car).
Mike Martus
Unread 26-06-2006, 01:00
I was just thinking, 67's 2005 robot (the 3-wheeled omnidirectional system) might have had 3 independently rotated drive modules. (A robot with 3 independently steered modules can perform the same maneouvres as one with 4.) See here for apparent confirmation of this fact.
Unread 26-06-2006, 01:11
RogerR's Avatar
AKA: Roger Riquelme
67's 2005 machine definitely had it, as did 312's 2006 machine (the latter heavily influenced by the former). the drive configuration of the simswerve would also lend itself to the same maneuverability of the 4 wheel independent. i think what is notable about the 47 bots' modules is not the fact that they are independently steered, but rather the fact that there are 4 of them that were independently steered.
Unread 26-06-2006, 14:08
I know, and of course Karthik knows, given SimSwerve; I'm just pointing that out so that others realize that 47's implementation wasn't the only one that allowed for arbitrary planar motion.
Incidentally, 47's 2001 and 67's 2005 designs drive all of their points of contact; 47's 2000 and 1114's 2005 drive only two points of contact, and leave the other two as casters—this retains maneouverability, but sacrifices maximum pushing force (because the total normal force on the driven wheels is lower, and they therefore exert less friction).
pic: Coaxial Swerve drive, lightened. CraigHickman Extra Discussion 19 22-06-2006 15:00
Swerve Drive Whitepapers/Info Ryan F. Kit & Additional Hardware 1 20-10-2005 00:51
Swerve Drive on a Jeep Karthik Math and Science 3 01-02-2005 17:50
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
