Go to Post Desperation is the mother of accomplishment. - Koko Ed [more]
Unread 23-06-2006, 23:57
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Re: Piezo Ignitor
You know it. I'm making a cool ignition system, hopefully.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 05-07-2006, 15:10
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Exclamation Re: Piezo Ignitor
Don't use a grill igniter... they are not very reliable. Trust me on this one. I just finished my fourth potato cannon setup: interchangeable barrels, muzzle breaks that throw flame, and a FLINT ingnitor. the first three I built used electronic ignition and were not nearly as reliable, they had maybe a 1 in 5launch rate, where as the flint one is good for 19 out of 20 launches. Plus they're alot cheaper.
The only, and I mean ONLY, benefit of electronic ignition is the ability to have multiple ignition points. I had a 9ft cannon (3 foot long, 4" combustion chamber, 6 foot long 2" barrel) that I wired two ignition points into, it was amazing when it worked, threw a caulking tube over a quarter mile, but it did not fire reliably.
My new one, being so much more relaible, is alot more fun. It also uses propae as a fuel. Propane is good because it's much cleaner, both for your gun and the enviroment, and cheaper, since all your money is buying fuel and not hair chemicals and advertising.
Unread 05-07-2006, 20:19
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Piezo Ignitor
My brothers friend made a potato cannon, and used a taser for his ignigtion. He has some videos here: http://video.google.com/videosearch?...+wetzel+potato
Wetzel
Viva Olancho!
Unread 14-07-2006, 18:10
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
Re: Piezo Ignitor
As far as potato gun ignitions go, ive had no problems at all with the push button grill sparkers. The only caveat is to make sure you clean the contacts where the spark will jump every so often. (and thats only cuase i use hairspray, not clean burning propane) My guns shoot at least 90% of the tinme when i i have enough fuel in them. So if you are having problems with them experiment with different amounts of fuel and keep you bolts clean. If that doesnt work you may just have a bad ignitor
