Go to Post The hardest resource to come by in FRC is the one you can't buy: a well-trained, experienced, well-intentioned, dedicated mentor. - PayneTrain [more]
Unread 25-06-2006, 03:57
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Motor Calculations
I was just looking at some things for the small CIMs and felt like doing a few calculations.
I wanted a output speed of 10 fps on a 6 inch wheel.
So the circumfrence of the wheel is about 1.57 feet this means it needs to rotate 6.36 times. This comes to 381.60 rpms.
I then looked at that data sheet and found the most efficient load and speed. which is 45.00 oz-in and 4614.00 rpms.
Ok so now you have to gear it down from the 4614 rpms to 381.6 rpms. this means you need a gear ratio of 12.09. So now I multiplied 45 oz-in of torque by the ratio, which gives me 544.05 oz-in of torque.
544.05 oz-in = 34 lb-in = 11.3 lbs is the max weight of this robot
This doesn't make much sense to me seeing as how teams use 2 CIMs the go faster then 10 fps and carry way more weight. this means from what I got to beable to carry the 133 pounds the max speed would be 10 in/sec.
From this I am thinking I went terribly wrong somewhere, If somebody could help me out with this it would be great.
Unread 25-06-2006, 04:25
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: Motor Calculations
Originally Posted by sparksandtabs
...544.05 oz-in = 34 lb-in = 11.3 lbs is the max weight of this robot..
this number is not the max weight of the robot, but rather the force the robot will create at the wheels (at this speed). to find the max acceleration at this point on the torque curve, divide this number by the mass (not the weight), which in this case is approx. 4.13 slugs. this will give you an acceleration of 2.73 ft/s^2.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 25-06-2006, 04:26
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
no, that seems about right... that's the amount of 'thrust' that will be at the wheel. So, at the max efficiency, your robot will have 11.3 pounds of acceleration pushing it forward, and that is while you are at 10 fps, when it is slower, you will have more acceleration then that.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 25-06-2006, 08:39
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Read this
Volume/Weight Calculations in Inventor =Martin=Taylor= Inventor 2 08-04-2006 10:21
Distance calculations Max Brin Programming 3 22-02-2006 21:38
External metal jacket on the Drill motor and FP motor, WHY? archiver 2001 3 24-06-2002 04:22
Seeding Calculations archiver 2000 50 23-06-2002 21:57
External metal jacket on the Drill motor and FP motor, WHY? Dennis Hughes Technical Discussion 1 04-06-2001 11:59
