Go to Post If by hazardous you mean thinking about robots 24/7, waking up at 2am in the morning to jot some ideas down, completely losing your social life, and staring at a computer until your eyes hurt, then yeah! :D - looneylin [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 25-06-2006, 14:32
mhrnetwork mhrnetwork is offline
mhrnetwork is an unknown quantity at this point
Help with RealVNC
Hello all... I am new here
I have a problem with real VNC and remote connection.
I have a local IP 192.168.XX.XX and my ISP gave me this IP and it is behind a Cisco Router so i can not make port forwarding !!!!1 if anyone have a solution for this problem i will be very thankfull.
thanks
Unread 25-06-2006, 20:05
neo's Avatar
neo neo is offline
whoa.
AKA: Dan Murrow
FRC #0585 (THS CyberPenguin Robotics)
neo has a spectacular aura aboutneo has a spectacular aura about
Re: Help with RealVNC
you should be able to use PuTTY to forward ports and such.
Unread 25-06-2006, 20:08
neo's Avatar
neo neo is offline
whoa.
AKA: Dan Murrow
also, this should tell you how to use vnc through PuTTY tunneling.
Unread 25-06-2006, 20:50
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
From within your network try going to 192.168.XX.1 (where XX matches whatever IP address you've been given) in a web browser. With any luck you'll be given an administrative interface that lets you set up port forwarding, etc.
If I understand your setup correctly then what neo suggested won't help you because the problem isn't you getting out, it's you getting in from the outside.
So, if you can't get the administrative interface and change your settings, then what you want is the opposite: a reverse tunnel. That setup requires that you have access to some machine somewhere else which isn't behind a firewall which doesn't allow incoming traffic. You could try http://techrepublic.com.com/5100-108...ml?tag=nl.e011 and http://www.macosxhints.com/article.p...50222062346277 for a bit of information (for Linux and Mac OS X respectively). There's probably a way to do it on Windows, too (Google for reverse tunnel).
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Unread 25-06-2006, 22:12
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
If I'm not mistaken, he's sharing a connection, such as through a corporate network or an apartment building, so accessing the administrative inferface won't work.
Unread 28-06-2006, 09:13
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Hamachi may help. Basically, it lets you quickly set up a (very secure) VPN, even if the server computer (your home, in this case) is behind a firewall.
I've never actually used it, but there is a Security Now episode which discusses it. (Don't remember which one, sorry. Quite a while back though.)
Unread 28-06-2006, 20:03
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
i second that hamachi recomendation...its a really good program for vpn's...really nifty for 'LAN-ing' over the internet in games and such (i use it a lot), and i'm almost certain it will work here too. (its also useful b/c u can share the files over the internet as if it was on LAN)
Rohan K
2008: Alumni, Helper
2007: Webmaster, Alumni
2006: Team Captain, Driver, Electrical/Electronics Head
2005: Safety Captain
Help With Programming! KWalsh Programming 5 24-02-2004 11:42
Help With Fuses Rhs953 Electrical 3 10-02-2004 16:36
help with Interrupts thoughtful Programming 5 08-01-2004 16:07
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
help with autoCAD!! Stacy General Forum 3 24-01-2002 22:20
