Go to Post Take it from a team that mastered tank treads and still hasn't built them in over a decade - it's not worth it. - Isaac501 [more]
  #31   Spotlight this post!
Unread 22-06-2006, 16:16
Re: One upping Dave: A Diet Coke and Mentos Rocket!
something that would pop out at the right pressure, like a cork or rubber stopper?
or fire to melt the cap off?
  #32   Spotlight this post!
Unread 22-06-2006, 17:04
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Maybe an axe or a hatchet to cut the top off. Hopefully one can get it going fast enough so the bottle doesn't take off early with the top still hanging on.
Just make sure your fingers are out of the way, first.
  #33   Spotlight this post!
Unread 22-06-2006, 21:44
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
Yeah, but I'd rather not use anything more dangerous than high pressure in a plastic container. (Especially not on my own property- ). The picture in my mind is two rocket launching pads (see below, attached) next to each other with two pieces of plywood. One has a nail in it, the other has a hole with a rope. Bungee cords are attached to the top of the bottle, which is set on the pads with straws to guide it. Pulling the string & therefore pulling the board, the bottle is pulled onto the nail, bungee cords release, bottle goes flying. I've attached a crude sketch for you all to look at. After looking at it, you can all say "You suck at drawing and your handwriting looks like chicken scratch!", because I've admitted it.
However, a cork might work. My only worry is that it would pop out too early, after I've shaken it, but before I've got it on the pad, and that would make a mess. Maybe taping the cork in and pulling it out with string, but I dunno. Suggestions accepted on this idea as well.
That's all for now, folks!
The Canuck
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
  #34   Spotlight this post!
Unread 25-06-2006, 17:30
Back after 4 years off
FRC #5279
well this is going into my plans for rocketry this summer (I Am in charge of model rocketry at a summer camp) In the mornings we will be doing traditional Estes model rockets, and in the after noons we do what ever I happen to come up with (IE water/air pressure rockets, Baking soda/Vinegar rockets, giant water balloon catapults, basically what ever I want to do.
For this one, I like the idea of a rubber stopper, that is what we use (slightly modified) for the water rockets. The only problem is it may shoot out before you can get it set up to launch. The method we use for launch is gluing straws onto the bottle and putting two wire coat hangers into a piece of ply wood separated the same distance apart as the straws on the bottle and slide the straws onto the hangers. this gives you a (slightly) controlled launch, this is what I would recommend, if any one has any other questions (or ideas) for me feel free to let me know.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
  #35   Spotlight this post!
Unread 25-06-2006, 19:00
Dylan's Avatar
Dylan Dylan is offline
FRC Mentor
AKA: Dylan Stoll
FRC #0830 (Rat Pack)
Dylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud of
Send a message via AIM to Dylan Send a message via Yahoo to Dylan
Here's an idea on how to launch the rockets on command:
1. Remove coke bottle cap.
2. Drill a small hole through both sides of the area with the threads.
3. Drop in mentos.
4. Quickly place a cork in the nozzle/neck, and hold it there.
5. Find a nail with a flat head, and tie some string around it just below the head.
6. Carefully stick the nail through the holes in the bottle and the cork, like this:
It will act as a pin and prevent the cork from popping out.
7. Shake bottle.
8. Place rocket on some sort of sturdy thing to use as a launchpad (I'm planning to use one of those cinder blocks with the holes in it).
9. Pull on the string to pull out the nail. The cork will be pushed out by the pressure in the bottle, and the rocket should launch!
WARNING: This idea is untested, and there is a chance that there will be a problem when the nail is halfway out.
BTW, Coke and Mentos are on sale at our local store!
Next month, we shoot for the moon!
"It's like timing a monkey!"-me (explanation avalible by PM request)
"You can't spread Democracy with the barrel of a gun" ~ Helen Thomas
2006 Great Lakes Regional Semi-Finalists (Thanks to our allies: Team 66 and Team 68)
Thanks 469 for lending us your old OI in ATL!
  #36   Spotlight this post!
Unread 25-06-2006, 23:35
CourtneyB
Posts: n/a
hahaha thats awosmee
  #37   Spotlight this post!
Unread 25-06-2006, 23:37
Melissa Nute's Avatar
Melissa Nute Melissa Nute is offline
I like my hammer...
Melissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond repute
Send a message via AIM to Melissa Nute
http://community.livejournal.com/ohn...t/7349072.html
Apparently Diet Coke and Mentos made the Approval Matrix...on the Brilliant side.
  #38   Spotlight this post!
Unread 25-06-2006, 23:48
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
I think the best solution to this has to be simple. All you really need is to find the perfect diamater hole to maximize the thrust of the built-up pressure. Of all the "tests" we did, the best results (e.g. farthest distance) occur when the cap of the bottle would be blown off, leaving the roughly one inch diamater opening as the thrust nozzle.
So to ensure the perfect launch, you will need to find a way to make the cap the weakest part of the bottle, so that it fails first. But at the same time it has to be strong enough to withstand the "normal" pressure of the built-up Diet Coke/Mentos reaction.
And as we also found, the body of the bottle itself will rupture sometimes before the cap would blow off. From these results you can conclude that if we had ever screwed on the cap of the bottle too tightly, then the bottle itself would break. But if the cap was not on very tightly - yet still on enough to keep the pressure contained - the bottle would blast off like a rocket.
So here's the challenge: to find a way to launch the bottle on a controllable launch angle, using this "cap tightness" observation.
Art Dutra IV
世上无难事,只怕有心人.
  #39   Spotlight this post!
Unread 25-06-2006, 23:53
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Already being designed. Due to come to fruition on July 1st.
Stay tuned.
  #40   Spotlight this post!
Unread 26-06-2006, 00:33
Ted Boucher Ted Boucher is offline
Its been awhile.....
FRC #0237 (Black Magic Robotics)
Ted Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond repute
Tonight I got bored and decided to think about all the designs I have made up since Samm's grad party. Only one of them stood out as the easiest and safest way to do this.
My design uses the "Pop Top" spout from a Poland Springs water bottle to replace the normal cap for the diet coke. I made this work easily with about 2 minutes of work with a dremel tool. This will hopefully create the most likely weak point in the bottle and exert all of the created pressure out of it. As used at the party, I will use plastic wrap to store the mentos until the bottle is shook. The pop top has a clicked in position to keep the cap closed. This will hopefully pop open when there is to much pressure in the bottle. If this does not work, then it could also be manually opened. The spout restricts the opening from a .841 inch opening to a .298 inch opening, and should give it much more power.
I will be testing this design out tomorrow, and will repost my results.
FRC Team 237 Alumni (04-07)
Western New England College Class of 2011
FRC Team 237 Mentor (11-?)
  #41   Spotlight this post!
Unread 26-06-2006, 01:39
Hmmm...
Would it just blow up, or fly if launched correctly? Let's find out.
  #42   Spotlight this post!
Unread 26-06-2006, 01:42
Dylan's Avatar
FRC Mentor
AKA: Dylan Stoll
Originally Posted by Elgin Clock
Hmmm...
COKE GRENADE!!
  #43   Spotlight this post!
Unread 26-06-2006, 01:45
Originally Posted by Dylan
COKE GRENADE!!
Nope.. no grenades here officer.. Just my beverage and some candy.
<shifty eyes>
And, on a related note, a chat I just had with Ted from my team:
Me: lol well.. they are based outside the US (Mentos)
Me: lol
Ted: ahhhh
Ted: it makes sense now
Me: Parfetti Van Melle - Holland
Me: made for Parfetti Van Melle USA Inc. Erlanger, KY
Ted: someone was prolly trying to secretly sneak explosives into the country with mentos
Me: LMAO
Ted: and it has finally come out
Me: AHAHAHAHAHAHAHA
Me: should I notify homeland security?
Me:
Ted: yes
Ted: and tell them that you think the declaration of independence has a secret map on the back that leads them to the factory
Me: LMAO
Me: Like National Treasure, but this is the greatest modern engineering treasure ever!!! maybe.. maybe not.. LOL
  #44   Spotlight this post!
Unread 26-06-2006, 01:48
Dylan's Avatar
FRC Mentor
AKA: Dylan Stoll
^ lol, I am so spotlighting that!
  #45   Spotlight this post!
Unread 26-06-2006, 10:48
COKE GRENADE!!
#1: AWESOMENESS!!!! Where do you get those lol?
3. Drop in mentos.
7. Shake bottle.
#2: Awesome idea, that could really work!
And finally, #3: Will somebody PLEASE tell me HOW THE HECK YOU PUT A PICTURE IN A POST WITHOUT CREATING A NEW THREAD?!?!?!?!?!?! It annoys me to no end that I can't do that without making it an attachment. Dylan, you know how to do it- PM me with how, PLEASE!!!!!!
Enough...now time to do serious work (*cough* games *cough*)
The Canuck
I think these guys have just one-upped Dave... geeknerd99 Chit-Chat 11 22-11-2006 19:18
pic: Mentors and Mentos MissInformation Extra Discussion 33 05-06-2006 08:33
One-upping JVN. Joe Matt Chit-Chat 13 06-09-2005 23:47
pic: Big Mike and Dave and Brandon dlavery Extra Discussion 11 27-04-2005 10:43
Former FIRST student and mentor dies in a tragic rocket attack in Iraq today. Munkaboo General Forum 48 19-04-2005 12:21
