Go to Post Lighten it up a little to bring it in under the 120 pound weight limit, and I think you will have something there! - dlavery [more]
  #46   Spotlight this post!
Unread 26-06-2006, 12:24
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: One upping Dave: A Diet Coke and Mentos Rocket!
Originally Posted by robotcanuck1676
And finally, #3: Will somebody PLEASE tell me HOW THE HECK YOU PUT A PICTURE IN A POST WITHOUT CREATING A NEW THREAD?!?!?!?!?!?! It annoys me to no end that I can't do that without making it an attachment.
http://www.chiefdelphi.com/forums/sh...06&postcount=3
& Keep in mind:
http://www.chiefdelphi.com/forums/sh...14&postcount=5
Simple.
  #47   Spotlight this post!
Unread 26-06-2006, 14:09
Ted Boucher Ted Boucher is offline
Its been awhile.....
FRC #0237 (Black Magic Robotics)
Ted Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond repute
Well.... things went bad for me.... lol. So it all went fine and good till I shook it up and the hot glue seal that I made around the cap and bottle broke. It failed to take off but succeeded in making a nice mess on my pants.
The picture in my mind is two rocket launching pads (see below, attached) next to each other with two pieces of plywood. One has a nail in it, the other has a hole with a rope. Bungee cords are attached to the top of the bottle, which is set on the pads with straws to guide it.
Well after mine failed I decided to break out my estes rocket set and see how well one of those launch pads would hold up. The upright pole is very very flexible and is only made for a very light weight rocket. I think if you did use these stands, the coke bottle would go anywhere it wanted to anyways.
FRC Team 237 Alumni (04-07)
Western New England College Class of 2011
FRC Team 237 Mentor (11-?)
  #48   Spotlight this post!
Unread 26-06-2006, 14:38
LOL Oops. So, Ted.. need any supplies from Home Depot tonight? I prolly won't be able to give them to you till Saturday anyways, but just wanted to know.. Text me and let me know.
Plans are underway!!! Oh yes.. plans.. plans are good.
  #49   Spotlight this post!
Unread 26-06-2006, 16:05
lol probably not elgin... right now the only idea i have is to make it go boom..
So since my last post, I created quite an ingenious liftoff method. I used a tornado tube soda bottle connector, a full bottle of diet coke, and the 2 halfs of a cut up soda bottle. This used equal pressure to plug the hole of the diet coke until the reaction took place.
The 2 parts to this rocket:
Part A: This included a full diet coke bottle, the tornado tube connector, and the top screw half of a soda bottle.
Part B: Was the base part of a cut in half soda bottle.
I first wrapped a full tube of mentos in saran warp and inserted them into the open bottle of diet coke. Then I screwed on the tornado tube to complete the assembly of Part A. I then Part B over the cut in half section of bottle on Part A. This created a nice suction and made it so there were 2 equal sets of pressure on either side of the tornado tube. Then I turned it all upside down so the diet coke bottle was on top in the air, and the 2 halfs sections were on the bottom. To my enjoyment, the seal stayed and the diet coke was suspended in the top of the bottle only though the pressure. Then I shook Part A until the reaction took place and the newly created high pressure of Part A rushed into the lower pressure of Part B. There was enough pressure to have Part A shoot out of the base of Part B and fly up a crazy 2 feet in the air (grrr) and crazy down and spray me with diet coke.
I was quite happy with this experiment, and I am sure someone can improve upon it. lol The basic problem of it was it lost off if its power in the liftoff stage. It also tryed to lift off right when the pressure started to go off, with the original, it was shook up good and had built up a great deal of pressure.
I will post pics later on so it will be easier to understand, good luck everyone!
  #50   Spotlight this post!
Unread 26-06-2006, 17:04
Just out of curiosity, has anyone instrumented a Coke/Mentos bottle yet?
It would be interesting to see how much pressure builds up in the bottle
you can easily get 100 psi with a quality bicycle tire pump. If coke/mentos does not exceed this it would be less expensive to perfect the bottle rocket using water and air pressure
and save the Coke/mentos for live-fire demos with an audience.
  #51   Spotlight this post!
Unread 26-06-2006, 19:49
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Here's some results from the Baker backyard, as performed by Rachel (9) and Andy (old kid):
Purchased at Kroger:
  • 2 packs of mint Mentos (each a 24-pack for $0.99)
  • 2 - 2L bottles of Diet Coke ($1.59 each!!)
  • 2 - 2L bottles of Diet Big K Cola ($0.59 each)
Tools & items used:
  • utility scraper
  • scotch tape
  • fishing line
  • small twine-like string
  • 11/64" drill bit
  • cordless power drill
  • 9-week-old puppy
Test 1:
Drilled a hole in the cap of a Diet BigK cola bottle.
Taped 2 mentos to end of small twine-like string.
Put 2L bottle on flat platform.
With cap removed, threaded string through cap, with mentos under cap.
Put cap back on bottle, ever so slowly.
Attempted to drop string into bottle.
String gets hung up on hole.
Results: Some fizz... 3-4" in projection... string impeded projection... Mentos dissolved slowly.
Overall results: puppy licks platform, wife gets camera, kids get wet, just enough promise to try bottle #2
Test 2:
Used the same cap in experiment #1.
Used the #2 Diet BigK Cola bottle.
Listened to Rachel, saying "we gotta cut the mentos in half to get the Coke to dissolve it faster".
Used the utility scraper to cut the Mentos in half.
Taped 4 mentos halves to string.
Inserted mentos onto cap as in test 1.
Dropped string and mentos into bottle (had to push the string a bit)
Results: lots of fizz... once string and mentos goes into bottle, got a 6-8 foot projection... puppy licks bottle, kids drink soda and don't like it... wife laughs.
Test 3:
Used the same cap as test 1 and 2
Used the #1 Diet Coke bottle.
Replaced the string with fishing line.
Taped 5 halves of mentos on fishing line.
Inserted fishing line into hole, suspending mentos above Cola, fastened cap to bottle.
Yank out fishing line, releasing mentos halves into Cola.
Results: 10-12 foot projection, just like the guys in the white suits on the video... puppy licks grass and bottle, kids get excited, Rachel and I do "high five"... wife gets the projection recorded on digital video.
Lessons learned:
Fishing line works great
Diet Big K Cola works as well as Diet Coke
Cut the Mentos in half before inserting into Cola
5 mentos halves will use up about 50% of the cola
Puppies like cola (no worries, she didn't get too many licks)
We're planning a July 4th fountain.
Andy B.
  #52   Spotlight this post!
Unread 26-06-2006, 19:54
Onward through the fog.
^ what is puppy's name?
~ Helen Keller
(1880-1968)
  #53   Spotlight this post!
Unread 26-06-2006, 20:00
She is mainly black, with some white highlights (paws, nose, tip of tail). She is a mix breed... named Oreo.
AB
  #54   Spotlight this post!
Unread 26-06-2006, 20:21
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
Thumbs up Re: One upping Dave: A Diet Coke and Mentos Rocket!
In the very first "rocket video" what was the reason of the ceran wrap? Can you explain more on it's use, and if you would do it differently next time.
My next trip out of the city back the the Homeland... I'm definitely gonna rig up something.
  #55   Spotlight this post!
Unread 26-06-2006, 20:25
The saran wrap is used to insert the mentos into the bottle to delay the release of them to the coke. This way you can insert them, seal the bottle, and shake the bottle. The shaking of the bottle will make the saran wrap release and the mentos will react with the coke. This a cheap and easy way to make a time release "fuse".
This can be used in many applications, like a baking soda/vinegar bottle explosion and other applications were you have to separate the reactants until they need to be mixed.
  #56   Spotlight this post!
Unread 30-06-2006, 09:39
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
So...the Today show had the creaters of the video that everyone has seen online. How they released the mentor is putting a fishing string through them, then a clip at the end. They release the clip and the mentors fall into the container. However, I'm not sure that this method could be adapted to launch a rocket. However, they said they use Diet Coke becuase it contains no sugar, therefore, no stickiness.
(sorry about grammar errors...I am in a hurry to not be late to work)
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
  #57   Spotlight this post!
Unread 30-06-2006, 12:39
That has yet to be proven to be the real reason. As is with most scientific experiments, it's more of a technical reason than a vain one. LOL
Anyways, I have still yet to see why diet cokes does work better than regular coke (and yes, it does my friends) but some hypothesize that it has to do with the artificial sweeteners in the diet coke, as opposed to the natural sugar found in regular cola)
This weekend, along with building my rocket, I plan on testing other various soft drinks for reactivity to mentos, and a new found slow release "ammunition source" which I shall keep under wraps till extensive testing can be done on my part.
But, so far.. let's just say I sacrificed a Bawls for the cause, and it works well. Mentos and Bawls works well, and my secret ammo and Bawls too, but I don't know how well since I just did the experiment in a plastic cup, with no nozzle for shooting like a soda bottle has and I can't judge pressure in a rather large open container.. yet..
**I like how Mentos tries to default to Mentors in the spell check. Next question I have is what happens when you drop Mentor(s) in Diet Coke?**
Maybe I'll test that as well this weekend..
Any volunteers? (shotty not it! *puts finger on nose*)
**shotty defaults to an interesting word as well. I think I will inform Brandon of that one and have it removed. LOL
  #58   Spotlight this post!
Unread 30-06-2006, 13:14
in between teams
AKA: Luke Van Oort
Confectioners sugar? Wait, that's fast release. Maybe altoids? Probably not sugary enough. Could it be BAWLS mints? Or maybe jawbreakers? Gargh, the suspense!
Team 1219: 2009 - Mentor
  #59   Spotlight this post!
Unread 30-06-2006, 13:35
That would be the logical difference. Regular Coke has the equivalent of 10 teaspoons of sugar in a 12 oz can. They use mostly corn syrup now, but it raises the viscosity of the liquid.
Diet coke is more 'watery' (for lack of a better word) than regular Coke, so it does fizz better. The viscosity extreme would be trying to make a rocket from carbonated peanut butter.
  #60   Spotlight this post!
Unread 30-06-2006, 14:38
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Originally Posted by sanddrag
That's nothing. Check this out http://my.break.com/Media/View.aspx?ContentID=111469
Beware of some of the content on the rest of the site.
Those guys were actually on Letterman last night. And Dave did his own Diet Coke/Mentos demonstration. Of course, one of his guests had to bring up the question about what happens if you eat Mentos and drink Diet Coke at the same time.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
I think these guys have just one-upped Dave... geeknerd99 Chit-Chat 11 22-11-2006 19:18
pic: Mentors and Mentos MissInformation Extra Discussion 33 05-06-2006 08:33
One-upping JVN. Joe Matt Chit-Chat 13 06-09-2005 23:47
pic: Big Mike and Dave and Brandon dlavery Extra Discussion 11 27-04-2005 10:43
Former FIRST student and mentor dies in a tragic rocket attack in Iraq today. Munkaboo General Forum 48 19-04-2005 12:21
