Go to Post I think rovers on Mars are way cool but you won't get a crowd of enthusiastic participants cheering as they trudge 150 meters a day. - Andrew Schuetze [more]
Unread 12-06-2006, 11:52
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: FVC GDC wants your feedback
How about allowing detachable auxiliary robots?
A large robot would be allowed to carry another robot that could be launched and (must be?) retrieved.
Each of the two humans on a team would control the one of the robots (either the Carrier or the one it deploys). This would be one option for doing things like pressing two push-buttons at the same time, or for gathering balls (by having the deployed bot herd them into the Carrier), or for holding one object in place while another is stacked/attached on/to it, or for whatever...
Maybe loosen weight, size, sensor, etc. restrictions a bit for a two-bot team; but keep the restrictions tight enough to force a division of capabilities between the two bots. Also keep the one-bot restrictions loose enough to make it possible to be successful using a single bot.
Blake
Unread 12-06-2006, 13:52
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
If the competition is still split into separate autonomous and operator controlled matches, modify the ranking system just a bit. The separate ranking of teams, then averaging of the rankings was a little tough to follow and in some cases I think it was unfair.
If a bunch of teams are tied in autonomous points (very possible since many teams scored low this year), the tiebreaker should not drop down to the random 'coin flip.' In some cases this can cause the 'wrong' team to be ranked higher. The random flip should only be used if the overall averaged rankings are tied.
For example... Teams A, B, C are all tied with 0 points in autonomous and are ranked 1, 2, 3 in operator controlled, respectively. It would make sense for the overall rankings to match the OC rankings, but it's not necessarily the case in the current system. If the random Auto rankings go B, C, A, for 1, 2, 3, the overall rankings will be B (1.5 avg), A (2 avg), C (2.5 avg).
It's a small change, but I think it's needed.
Unread 12-06-2006, 14:44
Billfred's Avatar
Billfred Billfred is online now
Just as a thought to the comment about foam tiles being somewhat expensive, what about a painted piece of plywood for the floor? Surely the Vex wheels can work with that stuff, and the price is right.
Going to the footballs idea, what about those hard plastic ones that folks throw into the stands as promos at football games? Cheap, durable, able to be decorated if FIRST wants to splurge, and they'll make all of the folks who have been clamoring for footballs in FRC happy.
Also, this should probably go without saying, but stick with the WildStang-designed field controllers. The system was functional, beautiful on the field (who wants a big beige crate at midfield with all that lexan around?), and displayed all the information we've wanted to know.
Unread 12-06-2006, 18:25
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Soft tiles are a little pricey, but judging by the wear and tear this season, they should last for several seasons and will only require spot replacement of worn tiles. The only thing I'd change, is to NOT punch holes (for the floor starting balls) like this year, then the tiles would be reusable. The small drywall screw holes didn't seem to leave big holes so they shouldn't be a problem in future years. While the tiles are pricey, have you priced good plywood lately? Then there is a problem with mating adjacent panels and warped plywood. The lack of friction would be an issue if anyone wanted to use tank treads for a drive train, and it's still a lot easier, not to mention lighter, to store a box of tiles than plywood or carpeting.
Other/General Game Ideas: I just thought of one. Can Dave or someone on the Vex GDC come up with our own Game Clue please. Always like a good puzzle!
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 12-06-2006, 18:33
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by skimoose
... Can Dave or someone on the Vex GDC come up with our own Game Clue please. Always like a good puzzle!
Amanda should get the honor of writing the official FVC Game Clue.
Richard Wallace
since 2003
Unread 13-06-2006, 22:19
Ken Delaney 357 Ken Delaney 357 is offline
FTC #101(Radnor Robotics)
FRC #0357 (Royal Assault)
Ken Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to behold
Autonomous Mode: Have several levels of challenge, where more of the sensors could be used.
Tele-Operated Mode: Fine.
Game Object(s): Easy to purchase. Consistent in manufacture. Different sized objects. A game component that rewards precision, for example placing an object in an area with small tolerances.
Goals/Scoring: Multiple methods of scoring is great.
Tournament Structure: I like keeping the autonomous separate from Human Control. I liked the fact that other robots could not interfere with our routine.
Other/General Game Ideas: The foam pads are a nice surface. However they did create a lot of static electricity. I would also like to see teams allowed to use some kind of material for protection, other than VEX metal. For example a thin plastic material used to protect the RC and cables from other robots. A better method to identify team alliance color, maybe the flags like FRC.
“Far better it is to dare mighty things, to win glorious triumphs, even though checkered by failure, than to take rank with those poor spirits who neither enjoy much nor suffer much, because they live in the gray twilight that knows not victory nor defeat.” ~Teddy Roosevelt
Thus spake the master programmer:
"A well-written program is its own heaven; a poorly-written program is its own hell."
Unread 19-06-2006, 17:58
Billfred's Avatar
I stewed on this idea for a bit, and I think it might work for something like FVC.
Imagine a big bin full of the game object du jour on each side of the field. (I'll assume ping-pong balls.) On all four corners of the field are tubes for robots to receve these balls, and a Vex bumper switch to cause balls to roll into the tubes.
Here's the rub, though--once in the tubes, the balls can either roll into the tube where your robot is, or another tube that empties out at the other end of the field. With good coordination and the right alliance partner, this is a non-issue--but if you're either unlucky or don't plan right, you're opening the barn door for the other alliance to steal some of those balls.
Unread 27-06-2006, 00:37
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Autonomous Mode:
Don't have different rules for this game (but keeping it seperate is fine). It would have been amazing to see ALLIANCES trying to decide which goals to attempt to gain control of, if they want to play defense, etc etc etc. The strategies would have been amazing.
Tele-Operated Mode:
I'm a fan of real-time scoring, but creating an accurate scoring system can be difficult (as proven by FRC 2006).
Game Object(s):
I liked the raquet balls, as a vast majority of teams were able to find a way to gain at least minimal control of them
Goals/Scoring:
The highest scoring option (the 10 point center goal) was open, and hard to defend (as the opponent could approach from any side), making it critical to play high volume offense in order to secure it (which I liked), but it could be easily overcome by the corner goals (which were much easier to defend and take quickly). I think the highest rewarding secondary scoring method (ownership in 2006) should be higher to ensure more action in regards to that scoring method. I also like how the primary scoring method (balls placed in goals) led to the secondary (ownership of goals).
I think autonomous should have some impact upon the elimination structure (say, match #3 is autonomous if it gets that far).
Either make the field smaller or add another robot to each alliance. The "action" was a bit sparse this year, at least compared to the FRC game.
Unread 27-06-2006, 08:17
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
To greatly reward cooperation between/among alliance members, how about devising a section of the field that can only be reached if two bots cooperate?
An example would be one drives up a ramp and reaches a "canyon" between the top of the ramp and the other side of the canyon. The cooperating bot drives into the canyon so that the top of that bot forms a bridge across the canyon. The bot at the top of the ramp drives across the bridge and scores some points.
Another example would to have one bot get into an elevator and have the cooperating bot be the motor (that bot has a "power-take-off = PTO" that makes the elevator operate and lift the first bot up to (or down to) a scoring opportunity.
Another example is requiring both/all bots on an alliance to press buttons (or do something a little more complicated), simultaneously, in order to open up scoring opportunities for one/all of them.
Blake
Unread 14-07-2006, 13:43
AdamHeard's Avatar
Lead Mentor
Autonomous Mode:
Autonomous should be combined with the normal modes to be more like FRC.
20+ seconds would be nice
Tele-Operated Mode:
Worked fine in my opinion, 2 minute matches asre nice
Game Object(s):
maybe a new object, but Balls have always been easiest imo
Maybe a time released device (2004), that could be set off early through completing a task
Goals/Scoring:
require balls to be shot?
some zort of zone system (similar to stack attack), where you recieved points for balls that were in your zone.
Some sort of multiplier/bonus in scoring. Like tripple play, or the double point ball from 04 (first frenzy?)
Keep it like FRC
Something similar to stack attack would be easy, and exciting.
Flat field. The slant didn't seem to have a purpose. Ramps are fine, but not when they are half the field and aren't a goal in themselves (like stack attack)
Unread 14-09-2006, 09:11
CharlieWilken CharlieWilken is offline
#0634 (Robowolves)
CharlieWilken is an unknown quantity at this point
What a fantastic game!!!!!!!!!!!!!
The only problem for me is my extreme extreme disappointment that we cannot fabricate parts for our robots. Official vex parts only makes no sense to me. My machine shop students now will not get to practise thier skills.
Unread 14-09-2006, 09:25
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Charlie,
It's great to see your enthusiasm for the game. I understand the disappointment, but remember FVC's main mission. From http://www.usfirst.org/vex:
"The FIRST Vex™ Challenge (FVC) is a mid-level robotics competition targeted toward high-school aged students. It offers the traditional challenge of a FIRST competition but with a more accessible and affordable robotics kit. The ultimate goal of FVC is to reach more young people with a lower-cost, more accessible opportunity to discover the excitement and rewards of science, technology, and engineering."
-Custom fabrication would really put a hurting on teams without access...
...and the rules do not preclude your students from custom fabricating parts for a Vex robot. You just can't put them on the competition robot.
For example, I have a student on our school team who used our CADD software and 3D printer to manufacture a "vex traction wheel". I told him in the beginning that the wheel couldn't be used in the Engineering class game or in FVC. However, I wanted him to complete the project because it pushes him and maximizes the use of our lab. It's a great learning experience.
I'm sure a creative leader like yourself can find a way to do both things, motivate the students, and still stay within the rules for FVC competition.
Have fun and good luck.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 14-09-2006, 10:28
The new game ROOLZ!!3!
I haven't finished reading the field description, but I'm wondering -- does that rotating center platform rotate electrically, or is it just pivoted in the center? I guess I need to RTM.
Nice work.
(A full-sized softball? Are you deranged? )
Unread 14-09-2006, 10:51
Billfred's Avatar
Well, if you want to split hairs, you -can- custom fabricate parts, so long as they meet the requirements of <R5> and <R9>. Of course, if the inspector can't tell whether it's a Vex product, you'll have to prove it through documentation as <R7> lays out. The key is to have it come from Vex components (and, to make your inspector happy, remain recognizable as such).
Look in CD-Media at some of last year's robots; I was a particular fan of South Carolina teams 4 (now 507, I believe) and 171 (now 1539):
http://www.chiefdelphi.com/media/photos/tags/fvc4
http://www.chiefdelphi.com/media/photos/tags/fvc171
(Those URLs may change with the renumbering, but just change the numbers in the links to the new numbers, and life will be good.)
They were two-thirds of the winning alliance at the Orangeburg pilot tournament, and 4 won the Create Award, which is the forerunner of this year's Inspire award. I'd call them two of the best robots in the state, and prime examples of what you can do with the Vex system (read: just about anything you can do with sheetmetal).
Unread 26-02-2007, 19:31
Jared W's Avatar
Jared W Jared W is offline
FTC #3228 (S.P.A.M. FRC #180)
Jared W is just really niceJared W is just really niceJared W is just really niceJared W is just really niceJared W is just really nice
Send a message via AIM to Jared W
Game pieces:
Even though i liked working with the softballs this year..
they tended to get stuck in odd places inside the robot because of their protruding laces. they would fit in some places but not others because the laces caused their diameter to enlarge.
For example, our robot had a channel down the middle for the softballs, most of the time they went down no problem, but if the softball went down just right, it would get stuck because of the laces.
I would recommend a uniform ball such as a raquetball. But then again the softballs might have been easier to pick up because of their laces..
NEWS FLASH: GDC changes Fix-It Window Times Billfred Rules/Strategy 5 27-02-2006 20:38
We want your feedback! Don Knight Regional Competitions 1 14-02-2006 17:19
What Regional is your FVC team going to? Kyle Love FIRST Tech Challenge 2 22-11-2005 13:55
**FIRST EMAIL**/Autodesk Wants Your Feedback! KathieK FIRST E-Mail Blast Archive 0 12-07-2005 18:22
New School Website- WANT *YOUR* FEEDBACK!!! Joe Matt Website Design/Showcase 17 30-06-2004 16:25
