Go to Post What has happened has happened. Humans were involved, mistakes made. Clarification will come... - Wetzel [more]
Unread 28-06-2006, 02:01
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Serial Communications
I am trying to create a GUI app using Qt 4 to control the pwms on the RC. I have no clue how to integrate serial port communications into it. Could someone lead to an article or software that can help with this? I have no clue where to even look.
Thanks
Unread 28-06-2006, 14:20
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Serial Communications
Check out serial ports code from Kevin Watson at http://kevin.org/frc/
http://www.mikesorrenti.com/
Unread 28-06-2006, 14:38
6600gt's Avatar
AKA: Lohit
Thanks but I need the code or software that will let my GUI program access/control the computer's serial port. That code is for the FRC.
Unread 28-06-2006, 15:16
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I can tell you about the C APIs. On Linux, it's in the Linux downloader (ifi-picloader) on SourceForge (which is down right now...). The basics you want is tcsetattr() and the termios struct.
Under Windows, you're looking for BuildCommDCB(), GetCommConfig(), GetCommProperties(), and a collection of other functions. (In MSDN.)
I don't know if Qt has functions built-in to handle configuring serial ports.
Unread 28-06-2006, 16:12
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
I have a question about the serial ports programming.
I am trying to connect an LCD module to the mini RC for creating a GUI that will help control the robot systems while testing and operating the robot (which will later be implemented on our FRC robot).
To do this I am using Kevin's edu_serial_tx code at http://www.kevin.org/frc/2005/ .
Problem is i am not a very knowledgeable programmer yet, and I have no idea how to send simple text to the LCD. For example
"To run motor test press 1
To run shooter test press 2"
(That is just an example. obviously we are aiming to have an entire interface to test all the subsystems, get information from batteries, sensors etc.)
If someone could help me with this I would really appreciate it.
David
Unread 28-06-2006, 16:29
6600gt's Avatar
AKA: Lohit
Am i looking for c++ source code that has these functions?
David:
for starters try printf("output");
There should be an example in the user_routines.c
Unread 28-06-2006, 16:41
AKA: Jamie Bliss
I would say look for the functions themselves. Microsoft does a pretty good job of documenting them.
http://msdn.microsoft.com/library/de..._functions.asp
Unread 28-06-2006, 16:45
What kind of LCD do you have and what kind of serial communication does it use (TTL, RS232, TTL-inverted)?
What serial options does it have?
I took a quick look at that code sample of Kevin's and as it is currently configured it expects your LCD to be TTL-inverted, running at 2400 BAUD, and hooked up to digital input 1 (although there seems to be some discrepancy in how that digital input is configured - you might want to fix that).
Unread 28-06-2006, 17:06
6600gt's Avatar
AKA: Lohit
How do I know how to set up each function??
I am ok with the PIC c programming but I am totally new to this type of programming.
Unread 28-06-2006, 18:33
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
If you are doing this on Windows why aren't you using .NET 2? It has serial I/O built in.
Maybe a better question would be if you are going to run this on Windows why are you using Qt? If the goal is to make this cross platform you might want to look at mono and glade, but each platform will still have different serial code.
Unread 28-06-2006, 21:40
6600gt's Avatar
AKA: Lohit
Can you refer me a resource/article on .NET 2 that I could get started with?
No, I don't need a cross platform program but Qt is the only program that I have found to date that has a simple, straight-forward interface. Do you have any better suggestions for creating windows GUI?
Edit: I am currently downloading Visual C++ Express with .NET 2 Framework. Is this what you had in mind?
Unread 28-06-2006, 22:14
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
I was writing a replacement for IFI Loader awhile back.
http://www.chiefdelphi.com/forums/sh...ad.php?t=38853
It's written in Qt (Qt3, however) and should compile for both windows and linux. I used some compiler directives to detect the platform and use the appropriate pieces of code. Look for the files called serialio.cpp and serialio.h in the "loader" folder. It's a class with functions to send and recieve data via the serial port. You should be able to use it as a starting point.
I have to warn you though that I have yet to figure out why it doesn't work on Windows XP. As far as I can tell, my code is correct. When I compile it, I don't get any errors. Interestingly the same binary will run correctly on Windows 2000 and WINE, but it will freeze on Windows XP.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 28-06-2006, 22:34
6600gt's Avatar
AKA: Lohit
For one thing I am using Qt 4, which seems to be quite different for Qt 3 form everything I have read. I still have to figure out how to pull the data form the sliders so I can send it in a struct over the serial port. As you can see I am new to this stuff so I am going to try Visual C++ and .NET 2(hopefully they will make life easier) but thanks anyway.
Unread 28-06-2006, 22:58
fowlerm's Avatar
AKA: Matthew Fowler
You can use VC++, but I use C#. You need to look at the System.IO.Ports namespace on MSDN. You are going to want to use the SerialPort class. A couple of examples (in C#) can be found here.
As for the UI, the windows System.Windows.Forms library is very easy to work with and has lots of controls. You can use the Trackbar control (which is the slider) to get input values and then send them to the RC with the serial port.
Unread 28-06-2006, 23:24
6600gt's Avatar
AKA: Lohit
First I would like to say thanks to everyone that helped. I just downloaded C# and it seems quite promising for me (a beginner). I am currently playing with it and we will see how far I can before I have questions again.
How technology has impacted communications in your life =) Nhiem Chit-Chat 4 20-05-2005 22:36
Spotty Radio Communications! Mr. Lim Control System 12 22-02-2005 20:47
Timer 0/Serial Communications? steven114 Programming 2 13-02-2005 20:50
Communications via the Programming Port Larry Barello Technical Discussion 9 10-06-2003 23:33
Radio Communications... Dan 550 General Forum 9 29-12-2001 17:00
