Go to Post A well-designed shifting transmission, controlled by an experienced driver (or a clever bit of software), is an advantage. - Alan Anderson [more]
Unread 01-07-2006, 20:36
CraigHickman
Posts: n/a
pic: 114 Coaxial Final CAD
Unread 01-07-2006, 20:39
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Re: pic: 114 Coaxial Final CAD
Looks good, but... it looks kind of weak at the top. If you get hit by say BOB with there 6 cim drivetrain, those two plates are going to bend and cause major headaches. It looks really nice though.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 01-07-2006, 21:18
CraigHickman
Posts: n/a
As for structure at the top, the main shaft is 1" diameter, running through two large mushing supported by two 1/4 inch plates. I'm not sure exactly how strong that will be (all my attempts at stress tests failed horribly), but it seems strong enough.
As for getting hit by a large robot, I think the wheel tread will slip before we get bent from other bot contact.
Unread 01-07-2006, 22:45
Joe_Widen's Avatar
Here, you could intergrate this circular plate I have on my crab drive. Then you just add a few teflon pieces with groves for it to ride in.
pic: Coaxial Swerve drive, lightened. CraigHickman Extra Discussion 19 22-06-2006 15:00
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Coaxial crab CD47-Bot Extra Discussion 9 08-02-2004 20:08
pic: Coaxial Lego doubble-wishbone crab CD47-Bot Robot Showcase 7 10-12-2003 12:10
pic: Coaxial Lego Crab drive CD47-Bot Robot Showcase 11 04-11-2003 14:45
