Go to Post At least I can appreciate the humor in this LOLCODE; it isn't funny when our our robot goes backwards in hybrid mode - sgreco [more]
Unread 02-07-2006, 15:45
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Battery Voltage variable on EDU controller
I am trying to use the battery_voltage variable in user_routines.c but I get this error when trying to compile..
Error [1205] unknown member 'rc_analog01' in '__tag_167'
Am I missing something?
EDIT
After looking at 'ifi_default.h' i found this block of code..
  unsigned char oi_analog01, oi_analog02, oi_analog03, oi_analog04;  /*rxdata.oi_analog01*/
  unsigned char oi_analog05, oi_analog06, oi_analog07, oi_analog08;
  unsigned char oi_analog09, oi_analog10, oi_analog11, oi_analog12;
  unsigned char oi_analog13, oi_analog14, oi_analog15, oi_analog16;
  unsigned char rc_main_batt, rc_backup_batt;
So i decided to try rc_main_batt and rc_backup_batt...
If found that if you took rxdata.rc_main_batt and applied the formula "current voltage = battery_voltage * 0.038 + 0.05; " found at the bottom of 'ifi_aliases.h' you get a value of 650.. im running the the controller off a wall adapter putting out 6 volts to i think this is pretty acurate.
Here is the code if anyone is interested..
float current_voltage = 0;
float average_voltage = 0;
int voltage_count = 0;
int i = 0;
int i2 = 0;
void Process_Data_From_Master_uP(void)
	Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
	current_voltage = rxdata.rc_main_batt; 		// Store current voltage
	average_voltage += current_voltage;			// Add the current voltage to the average stack
	voltage_count++;							// Increase the average stack count
	if (voltage_count == 39)					// If the stack is 40
		average_voltage = (average_voltage / 40) * 0.038 + 0.05;	// Get the average and apply formula
		i = (int)average_voltage;									// Truncate decimals
		i2 = (int) ((average_voltage - i) * 1000);					// Subtract to get decimals only and then multiply by 1000
		printf("Average: %d.%03d \n",i,i2);							// Print the two together to make it look like a decimal
		average_voltage = 0;										// Reset the stack
		voltage_count = 0;											// Rest the counter
	Putdata(&txdata);             /* DO NOT CHANGE! */
Thanks to Mark McLeod for example on how to printf floats...
EDIT
I just tried using
current_voltage = rxdata.oi_analog01;
and i get averages of 4.7 so im not sure what to think now.. can anyone clarify as to what one it is and why i get an error when i try to use the 'battery_voltage' aliase... also i just realized that the battery_voltage aliase points to 'rxdata.rc_analog01' which i cant seem to even find anywhere..
Unread 02-07-2006, 20:14
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Battery Voltage variable on EDU controller
Are you using the EDU header files? For those two fields (rc_*_batt), I have "res01" and "res02".
In ifi_aliases.h (EDU version), it has this macro:
 *---------- Alias for Battery Voltage  -----------------------------------------
 * current voltage = battery_voltage * 0.038 + 0.05;
#define battery_voltage rxdata.rc_analog01
Also, I'm pretty sure the formula is known to be inaccurate.
Unread 02-07-2006, 23:05
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Yeah im sure im using the right header files... i got it off the ifi website three days ago from this URL http://www.ifirobotics.com/mini-rc-read-me.shtml
Has there been an update or something?
The 8.2 (or 8.3) Battery Voltage Bug eugenebrooks Programming 167 21-02-2008 20:05
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
Battery voltage Josh Siegel Programming 5 22-12-2003 10:15
Battery Voltage Neal Probert Programming 3 09-01-2003 10:18
