Go to Post It's OK to make some mistakes, as long as you learn from them. - Doug G [more]
Unread 03-07-2006, 12:28
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
pic: Twin Fan Powered Vex Prototype#2
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: pic: Twin Fan Powered Vex Prototype#2
ahh cool! does it work? where did those fans come from?
Unread 03-07-2006, 12:56
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Can you reverse the direction of the fans?
Wetzel
Viva Olancho!
Unread 03-07-2006, 13:37
CraigHickman
Posts: n/a
As for steering, a servo controlled flap behind the fans, and putting an omni wheel on the front wheel would make steering like a boat possible.
For braking, a servo with a piece of rubber on the arm pressing onto a main axel, so once you disable the fans, the servo acts as a brake.
Unread 03-07-2006, 13:38
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
That is a work of VEX
lol
When you say main axle, do you mean rear axle, and are both wheels on the same axle?
Unread 03-07-2006, 15:08
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
The fans I got at Hobby People, they are High Power Lightweight FAN UNIT.
The Speed Controller clames to be reverseable but it doesn't do it on the VEX set.
The flap wont do much because the vex set itself is not really aerodynamic, but I will give it a shot.
The axes are seperate one axis for one wheel and one for the other.
Callsign: N6ARA
Unread 03-07-2006, 15:24
i like dirt's Avatar
i like dirt i like dirt is offline
&quot;Dude, I Know this Stuff!&quot;
AKA: Sagar
FRC #1694 (Dr. Phillips Tech)
Team Role: Electrical
i like dirt will become famous soon enoughi like dirt will become famous soon enough
I think I have an idea to help you with your steering. But you're going to have to sacrifice your original 3 wheel design. I suggest you turn it into a 4 wheel drive and using a rack and pinion setup of gears turn it into a car drive.
KILLER TOFU!!!!
Unread 03-07-2006, 15:28
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Or couldn't he just rotate the one front wheel he has now?
The tread would have to go back on that wheel, though
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 03-07-2006, 16:30
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
or, if another speed controller is acquired you could use the fans for steering. Slow one down as you turn its direction, kinda just like our larger robots...
-Mike
Unread 03-07-2006, 17:00
1902_Battery_SGT's Avatar
1902_Battery_SGT 1902_Battery_SGT is offline
100% charged 100% of the time
AKA: Scott
FRC #1902 (Exploding Bacon)
1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all
Send a message via AIM to 1902_Battery_SGT
for steering how about putting a servo on the front wheel?
Unread 03-07-2006, 17:59
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Read this reply I put on your first thread, it may help you with the speed controller issue and reverse.
Unread 03-07-2006, 18:58
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Yes! Your were right when you put it to neutral it stops then when you reverse it goes backwards, but not on full power. This means I can steer and brake by going backwards. W00t thanks so much! My plan B was to do it like jets when they land on aircraft carriers with that rope and hook idea. Thanks so much, I will try to get a video of it as soon as I can.
Callsign: N6ARA
Unread 04-07-2006, 14:06
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Are you using the stock motor on the fans?
Unread 04-07-2006, 15:09
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Team Role: Driver
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
As for steering you can do it the same way new cruise liners do it, rather than put a rudder behind the fan turn/angle the entire fan. This if done right would take -/= power to do that moving rudders or turning the front wheel. This technique has made cruise liners much more fuel efficient and is now standard, granted this is air, not water and fuel isn't your concern. It is still a way to solve the problem at hand.
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
Unread 05-07-2006, 16:29
travis48elite's Avatar
travis48elite travis48elite is offline
Achievement by working together
AKA: Ricci
FRC #3193 (Falco Tech)
travis48elite is a splendid one to beholdtravis48elite is a splendid one to beholdtravis48elite is a splendid one to beholdtravis48elite is a splendid one to beholdtravis48elite is a splendid one to beholdtravis48elite is a splendid one to beholdtravis48elite is a splendid one to beholdtravis48elite is a splendid one to behold
Send a message via ICQ to travis48elite Send a message via AIM to travis48elite Send a message via Yahoo to travis48elite
I must say that is very initiative and cool! I would like to see that thing in action!
Travis Ricci
Build/Assembly Mentor
North East Ohio FIRST Robotics Alliance
pic: Vex fan powered :D Arkorobotics Extra Discussion 9 03-07-2006 18:28
pic: Evil's twin - The Enforcer aka BINGO! Bharat Nain Robot Showcase 25 01-03-2006 00:01
pic: 1251 Prototype v 1.2 David Guzman Extra Discussion 28 16-01-2006 12:14
pic: Prototype robot cire Robot Showcase 3 13-04-2005 21:26
Twin Rovers going to Mars...hmmm archiver 2001 2 24-06-2002 00:51
