Go to Post There is almost always more than one solution to any engineering problem. One part of elegant design is picking the one that makes the most sense for a particular design problem, even if that means "breaking" some normally established "rules". - Jeff Pahl [more]
Unread 02-07-2006, 15:56
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
pic: Crabstyle
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 02-07-2006, 15:57
run the trap!!!
Team Role: Human Player
Re: pic: Crabstyle
Is the entire module made from one large piece of tubing?
Nice work.
-Philip J. Fry
Unread 02-07-2006, 16:12
Joe_Widen's Avatar
Re: pic: Crabstyle
Yeh. Its 3x3 aluminum square with a 1/8" wall thickness. The two horizontal plates will be welded on there.
Unread 03-07-2006, 13:22
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: pic: Crabstyle
Question: if those two horizontal pieces will be welded on, then how do you get the shaft for the wheel into the module.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 03-07-2006, 13:35
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: pic: Crabstyle
Nice design, it looks hella cool. lol-I still have the nor-cal in me
Hmm..I think standoffs to hold the plates together would make it easier to work with and maintain instead of welding it to make a box. Although, you may have to increase the wall thickness to say, 3/16" or maybe 1/4" just for safety.
I'm wondering, what do you have it geared at? What is the pitch of the gears, and the first stage of reduction?
Unread 03-07-2006, 17:03
Joe_Widen's Avatar
Re: pic: Crabstyle
"Question: if those two horizontal pieces will be welded on, then how do you get the shaft for the wheel into the module."
Thats a good question. I didnt think of that. I can always attach the bottom plate with L pieces and screws.
"I'm wondering, what do you have it geared at? What is the pitch of the gears, and the first stage of reduction?"
They are 20 pitch gears. Its a 10-1 total reduction. The first stage is 5-1 and the second is 2-1.
Unread 03-07-2006, 17:45
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Crabstyle
With only one CIM per module, you should be able to get away with 24 or even possibly 32 DP gears, significantly lightening the module.
2001-2004: Team 100
2006-Present: Team 254
Unread 03-07-2006, 18:18
Joe_Widen's Avatar
Re: pic: Crabstyle
Well its 3/8" face width and as of right now I have and extra 1/10 of an inch on either side of the second stage reduction between the first gear and cim. Heres what the inside looks like. O yeh, I dont know how I'm doing the shafts so I made it simple for now.
PS, I'm not exactly sure how to check the mass on Inventor 11.
Unread 03-07-2006, 19:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Crabstyle
For weight, go File>iProperties then to the "Physical" tab and click on a requested accuracy from the dropdown menu. Make sure the materials are set on all your parts (same menu/tab). It has been pretty much the same since at least Inventor 5.
Unread 03-07-2006, 19:54
Jeff K.'s Avatar
Hmm..now what?
Re: pic: Crabstyle
Like, Cory said, I think 20 pitch for the first stage is a bit overkill, and you might be able to get away with using 24 pitch.
I'm not sure what type of bearings you are using, but you can't go wrong with flanged bearings.
Did you add any space between the gears in the C-C distance? A 0.001 or 0.002 wouldn't hurt.
Unread 03-07-2006, 23:06
Joe_Widen's Avatar
Re: pic: Crabstyle
This is really the first time I've ever made anything in Inventor. The weight of the whole module gears included is "2.962E+000 lbmass" according to inventor in "Very High" Accuracy
Well, since the gears cant get any smaller, I dont know of any advantages of using 32 pitch or 24 pitch since the gears cant be any smaller (I'm using 3/8" face width).
I love flanged bearings too, adn yes I'm using them
I dont have extra space right now, but there will be in the final version.
Unread 04-07-2006, 00:30
Jeff K.'s Avatar
Hmm..now what?
Re: pic: Crabstyle
Oh, so the distances for clearances with 20 pitch is good and if you were to design with a smaller gear for pitch such as 24 or 32, some things would interfere?
Unread 04-07-2006, 00:40
Joe_Widen's Avatar
Re: pic: Crabstyle
Yeh, exactly.
