Re: pic: Twin Fan Powered Vex Prototype#2
Your were right when you put it to neutral it stops then when you reverse it goes backwards, but not on full power. This means I can steer and brake by going backwards. W00t thanks so much! My plan B was to do it like jets when they land on aircraft carriers with that rope and hook idea. Thanks so much, I will try to get a video of it as soon as I can. |
Are you using the stock motor on the fans?
As for steering you can do it the same way new cruise liners do it, rather than put a rudder behind the fan turn/angle the entire fan. This if done right would take -/= power to do that moving rudders or turning the front wheel. This technique has made cruise liners much more fuel efficient and is now standard, granted this is air, not water and fuel isn't your concern. It is still a way to solve the problem at hand.
I must say that is very initiative and cool! I would like to see that thing in action!
You know how jets landing on aircraft carriers with a cable, does anyone think that would work for this? Like have a cable out and have it hook on and slow it down?
#7
Why not just have it track in a circle? Bind up one wheel a bit, get in a large area of pavement, let it go, and when it comes back around at 20 mph, throw a coat on it.
Or you could just grab a friend and put him 75 yards downrange. |
#9
It also now has a name now, it's called "Kamikaze". The reason is that if you don't stop it .. it will commit suicide. There are no brakes no controls and it's going 20MPH in a specific direction, so it's a Kamikaze... sorta. ![]() |
#11
you could make it like a control-line plane and just tie a string/cable to it
#12
I just drove my RC car with the same speed control and there is something like a 1 second delay before you can go into reverse. And just like you said, there is less power in reverse. Make sure you calibrate it though if you haven't already. There's a chance you may get slightly increased performance.
#13
i would position a servo on each wheel and then just rub one wheel or the other with a bar connected to a servo. hit both wheels to stop.
| pic: Vex fan powered :D | Arkorobotics | Extra Discussion | 9 | 03-07-2006 18:28 |
| pic: Evil's twin - The Enforcer aka BINGO! | Bharat Nain | Robot Showcase | 25 | 01-03-2006 00:01 |
| pic: 1251 Prototype v 1.2 | David Guzman | Extra Discussion | 28 | 16-01-2006 12:14 |
| pic: Prototype robot | cire | Robot Showcase | 3 | 13-04-2005 21:26 |
| Twin Rovers going to Mars...hmmm | archiver | 2001 | 2 | 24-06-2002 00:51 |
