Go to Post Imagine the pressure on Dave Lavery - every time he sneezes someone assumes it's a game hint. - Gary Dillard [more]
Unread 23-06-2006, 14:58
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Search for ideas on how to make belts ...
My team captain asked me the other day if I could make belts in Autodesk. I thought about it and I don't really know how I would go about that, unless I just designed it to be stationary and not to rotate with the rest of the assembly. That should work fine, but I was wondering if anyone else might have a different idea.
void function(void)
  function();
Unread 23-06-2006, 16:17
pmax's Avatar
pmax pmax is offline
AKA: Peter Maxfield
pmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to all
Re: Search for ideas on how to make belts ...
Hi Folks,
Take a look at Design Accelerators. They can assist with all kinds of functional components, such as belts, gears, bolted connections, and the like.
Take a look at these demonstrations:
http://usa.autodesk.com/adsk/servlet...112&id=7218463
-Pete
Autodesk
Unread 23-06-2006, 16:48
run the trap!!!
Team Role: Human Player
As far as I can tell the Autodesk design accelerator can make a belt but actually getting it to turn sounds REALLY challenging .
If for instance, you had a pattern (3D or 2D) on your belt you would want that pattern to bend in relation to the belt and it's pulleys.
How would you do this? Well if I were you I wouldn't bother....
Why do you want the belt to actually move anyways? (or am I missing the point of what you are trying to do).
-Philip J. Fry
Unread 23-06-2006, 18:17
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Team Role: Driver
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
Ironically it is very easy to make belts/treads/chains in Autodesk 3dsm. Animate them too with a click of the mouse.
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
Unread 24-06-2006, 14:56
negfrequency's Avatar
negfrequency negfrequency is offline
the guy with the drawings
AKA: Willomatic
FRC #1559 (Devil Tech)
negfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nice
Send a message via AIM to negfrequency
ive actually been recently playing around with the chains, and i think ive got it down. I make a normal chain with constrained links(thankyou imates!) then i extrude a surface, throw it in as a part, where i add a transitional constraint as well as tangent, and the belt rotates just as it would in real life in a circle. It is quite incredible.
www.evolved-ideas.net
-KOP CAD parts available for download
You know your me if.....
5) your 91 honda civic dx drives @ warp .000005376, not 60 mph
4) You know what "Bi-directional parametric associativity" is
3) Playing Diabolo does NOT mean you are a level 24 mage.
2) You've discovered you can rearrange the letters in William to spell "I am Will".
1) Your bicycle is 3 times more expensive than your car.
Unread 24-06-2006, 19:39
void* Jake;
FRC #1178 (DURT)
Hmm. I'm not sure I understand you exactly, neg, and I'm not too familiar with transisional constraints. In any case, I wasn't really expecting much, but I figured I should ask anyway. I'll just make it unmoving for now. It doesn't really make much difference, but it would be cool.
void function(void)
  function();
Unread 24-06-2006, 21:52
AKA: Willomatic
alright i admit that explanation was rather lame.
transitional constraints allow an object to roll or follow a surface, kind of like how you shift from second to third in a standard car. The stick being one object, the track being the other.
by creating a chain, you are making several pieces that can bend on only one plane. constraining this chain to an extruded suface shaped similar to a belt with transitional constraints allows this chain to "roll" along the surface in a continual circle.
As far as i can tell, the large downside of this is the actual construction of the chain itself. Even with iMates, the file size can get annoyingly large and laggy if you dont have an average computer (yea mines below average).
if i get the chance, i will post a picture of this sometime.
Unread 24-06-2006, 23:22
void* Jake;
FRC #1178 (DURT)
Ahh, that puts things into perspective a bit more. Do you have to constrain each link to the spool individually, or can you include all their inside faces like a single face or something along that line?
void function(void)
  function();
Unread 25-06-2006, 09:28
AKA: Willomatic
i constrained like one every three, and it was enough without having to do more of them.
Unread 25-06-2006, 14:54
void* Jake;
FRC #1178 (DURT)
Hmm. I'll play around with that for a while then. Thanks.
void function(void)
  function();
Unread 04-07-2006, 20:14
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is online now
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
We asked the same thing during the season, and all the replies we got didn't help at all.
There is nothing for belts on Design Accelerator. If you aren't going to be animating it, just get the dimensions and extrude it. That's what we did
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
teach rookies how to search Ken Leung CD Forum Support 2 17-01-2005 00:03
Does anyone have an idea on how to make a joystick program for an operating board? necroprime Programming 8 09-11-2002 19:04
How do i make gears in inventor? mnkysp6353 Inventor 1 16-01-2002 02:31
Belts, Timing Belts, and Automobiles. Anton Abaya Technical Discussion 5 09-01-2002 19:21
Anyway to make it easier for readers to search for important info's? Ken Leung CD Forum Support 10 30-06-2001 14:47
