Go to Post Disclaimer: I am not an electrical engineer nor an electrician. I occasionally play one on CD. And when inspecting robots, sort of... - jvriezen [more]
Unread 05-07-2006, 13:45
StargateFan StargateFan is offline
StargateFan is an unknown quantity at this point
Re: Serial Port Help?
Originally Posted by Qbranch
I know its too late for this time , but you need to be careful which code you download to your microcontroller. Kevin Watson's serial driver hex was compiled for the PIC18F8722, while the vex controller uses the PIC18F8520.
These two processors are very different in that the 8722 has 4 flash memory banks and the 8520 has just one. This could cause the IFI bootloader to write only 25% of the code, or could possibly overwrite its own code during the programming process.
So does that mean I can't fix this at all?
Which Serial Port? crossedheart Programming 4 08-02-2006 11:35
serial port interface AMIRAM Programming 16 22-01-2006 21:16
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
USB to 9-pin serial port (HELP!!) n00b Technical Discussion 10 01-02-2004 21:25
No Serial Port Jeff Waegelin Programming 15 09-01-2003 22:29
