Go to Post To be blunt: how many motorized carts do you see parked on the side of Einstein? - Koko Ed [more]
Unread 06-07-2006, 09:19
run the trap!!!
Team Role: Human Player
pic: Swerve! (Module)
-Philip J. Fry
Unread 06-07-2006, 09:31
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: Swerve! (Module)
Originally Posted by from description
This is a close up of one of my modules.
I'm hoping to connect all the miter gears and sprockets (the lower sprocket is attached to the wheel) to the shafts with setscrews to limit machining.
From the bottom of the wheel to the top of the module is about 6" (not including the vertical shaft!)
Can you see anyway to make this simpler?
Comments appreciated.
I looked at your overall design and I like it there are just a few things that jumped out at me.
1) why don't you uses gears instead of the sprocket and chain for the last reduction? With this design you will need proper alignment of your shafts anyway and I can't see that chain being fun to fix if it ever breaks.
2)using setscrews for an application like this is a bad idea. They only have minimal engagement with the shaft and under load are very likely to release from the shaft. I would recommend using a key way on that shaft. If you are worried about machining, just know you can buy shafts with key ways already cut in them and it is very minimal to broach the gear and wheels. Even if you have to pay someone to do it for you it is a very cheap thing to do and only takes about 10 mins max.
3) how are you attaching your rotating plate to the wheel framework? it looks as though you are going to need access to the inside of this module for adjusting your miter gear alignment. A bolt hole pattern on the slim edge of your top plate, if you made that a touch smaller so it fits inside would seem to be a good solution.
Keep us up to date on your progress...I think you have a very elegant design.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 06-07-2006, 18:28
run the trap!!!
I thought about this when I was desinging it but I could'nt really see the advatages. I'm using 35 chain which has a breaking point of one ton, so I rather doupt it will break. My real reason for using 35 chain was that I wouldn't need to worry about tensioning, and could get by okay if the chain was just a little loose (unlike 25 chain which needs to be tensioned very precisely).
By rotating plate I take it you mean the top plate?
I was originally planing to weld it in, but then again I'm very inexperienced when it comes to miter gears. I suppose you're suggesting I leave some room to adjust them? Good idea.
-Philip J. Fry
Unread 06-07-2006, 18:49
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
It's not so much tension that causes chain de-rail/breaking, its alignment. #25 is more finicky because the chain is a lot smaller, correctly tensioning the chain helps some but if your alignment between sprockets is out of whack, the chain will hop off. #35 is a lot more forgiving, even if you had a noticable amout of slack in the chain, as long as your alignment is held true (and since it's housed in a box frame) it's not going to cause any real problems, unless you really hate backlash.
+1 on the keyway, pins and setscrews will only fail at this stage of the reduction, if you're having a hard time getting the machining done I can connect you to a few people =P.
As for that miter gear, I'd suggest just machining sleeves that sit on the shaft to prevent the gear from moving in any direction, if you make the gear adjustable in position then under the right circumstances it'll adjust itself (I'd actually just machine sleeves for the entire shaft, then you'll never have to worry about alignment during testing/competition). Then again, if you weld it in that works too, make sure you keep the keyway in there.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 06-07-2006, 18:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I think your programmers would be more happy if those were gears in there (less backlash).
Unread 06-07-2006, 19:02
24 Hours of LeMons?
Isn't simplicity one of the key elements of this design?
It doesn't look like you can directly swap the chain/sprocket element with two gears, so you're going to at least need 3, which means you'll need to add in another shaft and its bearings to support it, which means more machining, on top of the gear/gear stock you have to buy and machine as well.
Anyways, shouldn't the encoders be measuring data off the wheel/the shaft that it's connected to? If so I don't see backlash being a problem, unless you're doing dead reckoning, which I'm sure our programming mentor has something to say against =P.
I'm not advocating to keep the backlash, though, if you can get rid of it then that's good.
Unread 06-07-2006, 19:41
DonRotolo's Avatar
Back to humble
FRC #0832
Not sure why you think you'd need a third gear in there. Can't you just reverse the motor (in programming)?
Don
Unread 06-07-2006, 21:11
James114's Avatar
James114 James114 is offline
FRC #0114 (Los Altos High School)
James114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really nice
Send a message via AIM to James114
Is there any interference where the chain is going to be? I think from this angle it looks like the chain is going through the side plates... if it were there.
2004 - Drive Train- 2 Awards | 2005 - Drive Train/ Driver/ Team Captian - 3 Awards | 2006 - Mentor- 8 Awards
Unread 06-07-2006, 23:00
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Don
I think the third gear isn't so much for the reversal as it is for the distance. Looking at the distance between the two sprockets, you'd need the third gear as an idler just to make it reach.
oh and one more vote for keyway. DO NOT USE SET SCREWS!!! We had them on our transmission this year, and they were the biggest headache ever. We ended up getting the sprockets welded on at SVR.
Unread 06-07-2006, 23:52
24 Hours of LeMons?
Nuttyman54 got it right, its a matter of distance rather than motor orientation.
Unread 07-07-2006, 13:54
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The center-center distance on the sprockets is adjustable within the module -- particularly because you've thus far planned to use chain. I'm sure that you'd have very little difficulty finding a set of gearing that approximates your existing center-center distance and you'd save yourself a lot of headaches for doing so.
#35 chain does not require any more or less tension to operate properly. As mentioned previously, it's a bit more forgiving about alignment, but if you're already planning on using a set of miter gears in your drive, you ought to be able to align even #25 chain with sufficient precision to make it work.
You don't want to use chain in this application without an additional tensioning mechanism, however. Chain stretchs with time and use, so even if you've properly calculated the center-center distance to be a whole or half number of links, it won't stay that way for long. As the chain stretches, gravity is going to make sure that all of the slack ends up hanging off the bottom -- not engaging the sprocket and making the chain jump teeth. It won't be pretty.
--Madison--
...down at the Ozdust!
Unread 07-07-2006, 14:34
The reason i said no chain was not about breaking it was about miss alignment and the side loads that these modules might take. As far as gears go, an easy way to do this would just to make the top (smaller gear) larger, which would decrease the ratio and then change the ratio from the kit gearbox to each crab module. You can most likely match the ratios exactly with minimal effort.
Encoders, yes measuring them directly on the wheel is optimal but you will still have some backlash issues. But in actuality you can put your encoder anywhere in your drive system and just use a simple function in your software to adjust for actual wheel speed.
As for connecting the top I wasn't really worried about the alignment of the miter gears (as others have said spacers would be fine) I was just looking at the serviceability factor, especially if you decide to still use chain.
Unread 07-07-2006, 23:47
run the trap!!!
Thanks for the feedback.
One more question for you:
The vertical shaft is welded to the top plate. The top plate is 1/2" thick. Is this excessive? Would 1/4" plate work just as well?
-Philip J. Fry
Unread 09-07-2006, 19:57
negfrequency's Avatar
negfrequency negfrequency is offline
the guy with the drawings
AKA: Willomatic
FRC #1559 (Devil Tech)
negfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nice
Send a message via AIM to negfrequency
its a great design, and if you go about it right you can get complete direction control with only effecting your weight (i hate that constraint)
www.evolved-ideas.net
-KOP CAD parts available for download
You know your me if.....
5) your 91 honda civic dx drives @ warp .000005376, not 60 mph
4) You know what "Bi-directional parametric associativity" is
3) Playing Diabolo does NOT mean you are a level 24 mage.
2) You've discovered you can rearrange the letters in William to spell "I am Will".
1) Your bicycle is 3 times more expensive than your car.
pic: Vex Swerve v3 JVN Extra Discussion 22 08-09-2006 17:28
pic: Swerve! =Martin=Taylor= Extra Discussion 15 07-07-2006 01:58
pic: Swerve Assembly CD47-Bot Extra Discussion 3 23-01-2004 20:02
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 23-01-2004 12:11
