Go to Post The only thing that would finish this perfect day is a game hint... - [more]
Unread 08-07-2006, 19:26
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
pic: Crabstyle v3
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 08-07-2006, 19:31
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: pic: Crabstyle v3
First off, nice rendering
I find it interesting that you're using the window motors to turn your wheels. Is there a particular reason that you chose them?
I don't know much about motor characteristics, but from a practical point of view, I see them being a pain. This basically forces you to enable your robot to move your wheels, which causes you to have to set your robot up before setting it on the field. Maybe that's not a big deal, but I think that it limits your flexibility.
In the crab systems that we had in 2002-2004, we used the globe motor for steering with pretty good success.
Unread 08-07-2006, 19:39
Joe_Widen's Avatar
O yeh, I see what you mean about that. I was thinking I'd shoot for the window motors is because they have worm gears so they couldnt be back driven.
Edit\\ Im woried that we'll get hit and it will throw off the sensors
EDIT\\ think I'm going to have it so that one window controls the left side and one controls the right side
Unread 08-07-2006, 19:44
Are you worried about another robot reaching down and turning your wheels to knock you off course?
Wouldn't you be better off using the only motors in the kit with built in worm gears on something that would have a tendency to want to backdrive like an arm or a lift?
Unread 08-07-2006, 19:54
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
So are you going to be independantly rotating the wheels with separate motors?
We have a concept for crab drive and we have two window motors. The front set and back set of crab modules rotate together.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 08-07-2006, 20:43
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
Why does it matter if you can or cannot back drive them? Don't forget, you'll need to get a pot or absolute encoder on there to measure rotation of the module and a pretty decent closed loop feedback system to make your swerve effective. Designing and building it is only half the challenge. Getting a swerve to drive predictably and effectively is arguably harder than designing and building it.
If you intend to use this during the season, you should definitely prototype it this off season. I've seen so many teams(including my own) build a swerve and never get the full potential out of it for lack of intuitive controls and programming time.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 08-07-2006, 20:50
Joe_Widen's Avatar
I guess our programmer said he had everything under control on his end. So looks like building it will be the hard part. Thanks for all the feedback.
pic: Crabstyle v2 Joe_Widen Extra Discussion 12 08-07-2006 14:49
pic: Crabstyle Joe_Widen Extra Discussion 12 04-07-2006 00:40
