Go to Post It also annoys me that I can't get all my pants with zebra stripes - marshall [more]
Unread 05-07-2006, 20:21
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: pic: Twin Fan Powered Vex Prototype#2
You know how jets landing on aircraft carriers with a cable, does anyone think that would work for this? Like have a cable out and have it hook on and slow it down?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 05-07-2006, 23:47
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
The only thing that i can see possibly going wrong with that is if it hit the cable and then bounces back... Do you plan on just having a length of cable pulled taught between two poles or something?
Unread 06-07-2006, 00:20
Andrew Blair's Avatar
FRC #0306 (CRT)
Why not just have it track in a circle? Bind up one wheel a bit, get in a large area of pavement, let it go, and when it comes back around at 20 mph, throw a coat on it.
Or you could just grab a friend and put him 75 yards downrange.
-Sir Francis Bacon
-Albert Einstein
Unread 06-07-2006, 01:08
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Instead of binding a wheel why not just angle the front one?
Unread 06-07-2006, 01:37
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
ummm .. I did that to my friend and trying to catch a chunk of metal going 20MPH that has 2 fast fan blades is not a good idea. He actually slowed it down by kicking it a bit (not enought to damage it) and then jumped forward and used his hands to stop it. You can really get hurt trying to stop it.
It also now has a name now, it's called "Kamikaze". The reason is that if you don't stop it .. it will commit suicide. There are no brakes no controls and it's going 20MPH in a specific direction, so it's a Kamikaze... sorta.
Callsign: N6ARA
Unread 06-07-2006, 14:52
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
you could make it like a control-line plane and just tie a string/cable to it
Unread 07-07-2006, 23:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I just drove my RC car with the same speed control and there is something like a 1 second delay before you can go into reverse. And just like you said, there is less power in reverse. Make sure you calibrate it though if you haven't already. There's a chance you may get slightly increased performance.
Unread 08-07-2006, 13:29
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
i would position a servo on each wheel and then just rub one wheel or the other with a bar connected to a servo. hit both wheels to stop.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 09-07-2006, 17:28
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Steering & Braking Options (some already discussed)
  • Two Hooks, one on each side. A servo on each can drag the on the ground to steer. Put both down to slow down or stop like a carrier landing.
  • Two bars, one on each side. A servo on each bar can drag that bar on a rear wheel to slow that wheel.
  • Get control over the fan speeds.
  • Mount the fans on rotating platforms aimed by geared servos. Point the fans toward opposite sides to stop. Point them at the same off-axis point to steer.
  • Stop (once) by deploying a parachute that is attached to the car and catches all the wind from the fans.
  • Turn (and slow/stop) by dropping raising baffle plates behind the fans. To stop have the plates block all thrust coming out of the fans (leave a gap between the plates and the fan.
  • Turn by putting a rudder (on the nose or) aft of the fans. Aft is better.
  • Stop by lifting the nose wheel and letting a nose mounted skid plate create enough friction to slow you to a crawl.
  • Turn by making an "active" chassis that uses a servo to slightly alter the rear wheel alignments and makes the robot turn.
  • Stop by running into a pillowcase or net (or high grass).
  • Stop by running your power through a switch that only remains closed if you have a command from your remote telling a servo to keep it closed. Good for safety...
[edit]
  • My wife Jodie came up with this one - Raise and lower air-dams (sort-of like the ailerons on a wing) to create enough drag to turn it, instead of using a rudder.
  • Instead of popping a chute; for a one-time stop, you could drop a grappling hook or anchor.
I still like the idea of plates that open/close over the back of the fans to let thrust out and/or point it. It will have sort-of a jet engine look to it; can be controlled by chains and sprockets from the middle of the machine; and if the default is to block the thrust, they will give you both a smoothly controlled start-up and a failsafe mode (I think you can rig this using just the default code).
[/edit]
Also - Put some shielding (strong screening won't hurt airflow but will keep fingers and other debris out) on the front and back of those fans, and some padding on the leading edges of this missile. Do it before someone gets hurt....
Blake
Unread 09-07-2006, 17:59
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Blake
The two hook idea is excellent I think I will try that, it is cheap and easy to make. Plus I just want to experiment around, I want to see if it works. So thank you.
And yes.. I did put a cover over the fans that don't effect the intake, and still give out the same power.
Callsign: N6ARA
pic: Vex fan powered :D Arkorobotics Extra Discussion 9 03-07-2006 18:28
pic: Evil's twin - The Enforcer aka BINGO! Bharat Nain Robot Showcase 25 01-03-2006 00:01
pic: 1251 Prototype v 1.2 David Guzman Extra Discussion 28 16-01-2006 12:14
pic: Prototype robot cire Robot Showcase 3 13-04-2005 21:26
Twin Rovers going to Mars...hmmm archiver 2001 2 24-06-2002 00:51
