Go to Post ...why do programmers have a nesting habit? - Andrew Schreiber [more]
Unread 30-06-2006, 23:38
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Bipod Control
I am not really sure what thread to put this in. I am starting a new project when I get back from vacation, I want to make a walking bi-pod robot using hobby servos. The uC will be a Atmel AVR ATMEGA16 and to control the servos I will outsourcing to THIS. The servo controller works off of USART and takes 3 commands, start (0xFF) servo # and servo position (0-255).
The actual construction will be relatively simple considering I want to start small then expand once I have this working good. One problem is I am not using a gyro >_<. But it will have several parts, the feet, the lower leg, the upper leg and the platform the controls sit on. This means there is 3 joint per leg which also means that the legs only move on one plane. Part of the control problem is that I don't know a good way to make it turn. I was thinking making the inside step smaller. Also if it matters I will be having 2 switches per foot to know that the foot is flat on the ground.
Unread 30-06-2006, 23:44
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Bipod Control
If you want to look at some cool bipods look at www.lynxmotion.com it might give you some ideas...
Unread 07-07-2006, 23:47
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Re: Bipod Control
if you search through the pics you'll find the pictures of my Robo one legs. Which is basicly what your describing. I used a BASIC atom control board because it supported up to 20 servos. After i built the legs i found that the servos i was using didn't have enough stall torque to do any real acrobatic maneuvers, so i had it walking for a few weeks and then i put it in my closet until i can afford digital servos (100 a pop) . BTW i didn't use a gyro, you just have to tweak how much you move each servo. And the way i figured out how to make it turn was to stand up and do it myself. easiest way to do it is to pivot on one foot, so while one leg is moveing the other just stands there and the whole thing pivots on that axis.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 08-07-2006, 20:56
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: Bipod Control
I was thinking just making one leg step longer than the other like how a car turns (kinda sorta, maybe?) and it would work itself out.
Unread 11-07-2006, 20:59
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Re: Bipod Control
Depending on how natural you want it to look.... you could probably make it just keep one leg shuffling on the floor and make the the other take the turning strides.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
No control team1500 Electrical 1 19-02-2006 19:07
Control Theory DanDon Programming 7 12-01-2006 13:15
control thingy CBaoth Control System 5 20-11-2005 22:34
Control gloves Jeff666 General Forum 0 01-04-2003 19:15
Control Systems archiver 2000 1 23-06-2002 22:15
