Go to Post Mark McLeod, one of the resident experts on compiler weirdness - Kevin Watson [more]
Unread 11-07-2006, 21:17
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Re: Magnetic Reed Switches and cylinder boom positions????
Originally Posted by ghhs_1527
the other option, instead of diodes, is run both off 2 diff spikes and have the 2 outputs on a spike ( M+ and M- ) connected to the positives on a solenoid ( one spike per solenoid ) the negatives from the solenoid are crimped togeather and run to the gnd on the spike (you will have to make sure you crimp another wire with them to run to the gound on the breaker panel) and have an on/off switch programed to the main one and have a push button ( arcade style ) programed for the exaust one.
We did this on our '05 bot...worked wonders
Controlled two huge cylinders (so they were completely multi-positioning) with only 3 spikes
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
