Go to Post Ice cream is an iterative process. - JVN [more]
Unread 10-07-2006, 21:41
FIRST JerseyKid's Avatar
FIRST JerseyKid FIRST JerseyKid is offline
Alumni
AKA: Erik Cokeley
FRC #0025 (Team Mercury)
FIRST JerseyKid is on a distinguished road
Send a message via AIM to FIRST JerseyKid Send a message via Yahoo to FIRST JerseyKid
Re: Range finding/sensor advice
Hi, I've been working on a project simular to this.
My large scale project is to make a system for autonomous vehicles to use sensors to make autonomous decisions.
First I needed to learn some stuff and try things out. So for the past 2 months every day for about 6 hours my professor and I would meet at Barnes and Noble and work on an autonomous vehicle. So we set out to do a small auton vehicle first. We came up with lets try to make a vehicle that could drive to a light, and follow if it moved. At first I was planning on making my own vehicle but after exploring options I found an rc car from radio shack that would work. Heres a link to the car H2 Car.
So using pic chips and electronics we built our own driving boards and hooked them up to sensors and its working pretty good now. We made H bridges and used op amps and did alot... If you have any questions about how to do anything with the sensors or code email me at FirstJerseyKid@comcast.net. Im programming my car in "restricted" assembly.
Team 1089 alumni coach.
Unread 12-07-2006, 20:07
Ken Leedle Ken Leedle is offline
College Student
FRC #0706 (CyberHawks)
Ken Leedle will become famous soon enoughKen Leedle will become famous soon enough
My first robot was very similar to this. I took the top off a RAD robot and used the base as the base for my autonomous vehicle. I designed the entire control system based on two PIC18F458s (I wasn't ready to tackle 80 pin TQFPs as a sophomore). It took me five tries to make a motor controller that met my requirements. It was able to navigate effectively in my house using a polaroid ultrasonic ranger on a servo platform and bumper switches. It also had IR proximity sensors but I found the sonar to be more effective. It took me forever to write the code for it in assembly. About a year ago, I decided to rewrite the code using the student version of the microchip C compiler. Took me a half hour to write the code that took me weeks in assembly.
Finding range DanDon Programming 11 10-01-2006 22:58
Camera Range Finding russell Programming 9 31-01-2005 19:54
ir beacon range doy Programming 10 29-01-2004 16:46
IR Sensor Range Problems KBMSora Technical Discussion 3 19-01-2004 14:10
Optical range sensor Ben Mitchell Technical Discussion 9 12-01-2002 00:11
