Go to Post Yes, I think we can all agree that bad people suck. - Joe Johnson [more]
Unread 12-07-2006, 21:07
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: Bandsaw Troubles
If you're doing straight cuts (or attempting to ) you could try clamping a fence to the table. This should help, and since that one never came with a fence and piece of straight stock, wood or metal would work.
Another thing to be aware of. The blade guides, whether they're friction blocks on lower models or actual live bearings on better models, are attached to the blade guard on the top side. If you're cutting a 1/4" piece have the blade guard set for about 1/2". If you have it set up real high the blade will lack support close to the work and be able to twist easily.
Play with the speed at which you're feeding it like Ken said. With plastics they can, and will, heat up. If they get too hot they can melt and clog the teeth in the blade reducing you're cutting ability and causing it to wander.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Camera Troubles cmurdoch Programming 9 11-02-2006 11:34
IR Beam Troubles Goldeye Programming 2 21-01-2006 17:15
Tilt Troubles Mumford 406 Programming 4 29-03-2005 22:19
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
MMH Troubles Justin Stiltner Kit & Additional Hardware 3 28-01-2004 16:03
