Go to Post I searched the web for a good forum and it looks like this is the place to be. - Pipisongo [more]
Unread 12-07-2006, 21:19
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: Bandsaw Troubles
Originally Posted by KenWittlief
besides what Don said, get some material you can practice cutting. You might be pushing the material to one side without realizing it, making the blade twist.
Like most power tools, getting it to cut is easy, being able cut exactly down the center of a pencil mark, without tearing up the material, takes lots and lots of practice.
while you are cutting experiment a little. Instead of turning the material more and more try pushing it a little to the left or right and see what happens
or try turning it the other way. Power tools dont always respond like you think they should. you gotta develop a feel for it.
I know I am good on a bandsaw because on the ones at school I can cut dead center down a pencil line really fast. That is why I know something on my saw isn't right.
I tryed the fence Idea, the blade just walks the other way. i will try some of this tomorrow more, when people aren't sleeping. I was pretty sure I had it set up the right way :-\
Unread 12-07-2006, 22:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
My guess would be the blade tension is too low or the guide is too high.
Unread 13-07-2006, 02:05
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
You could also perform a test by using different thicknesses of plastic, wood, and aluminum, noticing when the blade feels like it is running wrong. As sanddrag suggested, try adjusting the tension of the blade tighter. You could also be feeding too fast, which would cause the blade to twist off your marked line very easily.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Camera Troubles cmurdoch Programming 9 11-02-2006 11:34
IR Beam Troubles Goldeye Programming 2 21-01-2006 17:15
Tilt Troubles Mumford 406 Programming 4 29-03-2005 22:19
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
MMH Troubles Justin Stiltner Kit & Additional Hardware 3 28-01-2004 16:03
