| You trip my breaker. |
#16
Re: The speed of light is NOT a constant?! A milestone in Physics?
And incidentally, if we're just talking about fundamental dimensions*, then of course it works—you wouldn't have much of a physical law, if the sides of the equation were dimensionally different. So, basically, the equation doesn't change dimensions. Energy is defined fundamentally as [M][L]2[T]-2, and mass is [M]. And if the speed of light (in a vacuum, to be precise) changed, then any quantities derived from it would also change proportionally—but the fundamental unit [L][T]-1 would remain the same. So the equation would still hold, with a different c, which changes with time (and more than likely spawns a horde of differential equations describing some other previously-static quantities changing proportionally with time). *Fundamental dimensions are units such as [L], [M] and [T] (length, mass and time, respectively), which form the basis for dimensional analysis. |
#17
the established SI units had no relationship to the energy stored in the bonds between protons and neutron but it was not necessary to balance Einsteins equation - as you said, K = 1 how did the speed of light just happen to fit the equation perfectly, so it was not E= 1.2783729832987 * MC^2 ? or some other correction constant? Thats the part that blows my mind! The established SI units were more or less arbitrary. A second is proportioal to the rotation of the earth on its axis - a meter is about the distance from someones nose to their fingertip, a kilogram is about one cubic centimeter of something or other.... so how did those arbitrary units come out perfect for nuclear energy? Last edited by KenWittlief : 13-07-2006 at 08:19. |
#18
#19
and these units were already established long before Einstein realized that matter could be converted directly into pure energy - but his equation came out exactly perfect. Theres more to the root of this than meets the eye here. The odds of that equation just happened to come out perfect, without the need for a correction factor are infinity to one. There is some deeper connection here. Ive never heard anyone attempt to explain what it is. Before Einstein's equation, energy and power were defined in terms of how much energy it took to raise one gram of water one degree C, or how much energy it took to raise 1 kg of mass one meter above the earth. These things have nothing to do with the speed of light, or the energy contained in the mass of an atom. Last edited by KenWittlief : 16-07-2006 at 17:18. |
#22
E = γmc2 Where the Lorentz factor γ = 1 at v = 0. This equation defines all of the energy in the point mass. If this were a physical object, we'd be evaluating the sum of all sorts of energies, but here, since we're only considering a point mass at rest with respect to itself, we can exclude kinetic energy (v = 0), potential energy (w/r/t itself, no internal energy), thermal energy (no motion, so no heat), etc., since they're all zero. What we're left with is the trivial equation: mc2 = mc2 mc2/mc2 = 1 Which is the unity constant of proportionality, provided that you're measuring everything in the same units. (Of course this presupposes that these relativistic equations are correct—but apart from the quantum scale, this is how it's defined.) When incompatible units are being used, in order to maintain dimensional equivalence, you need to insert a conversion factor. But if you take your energy in J = kg·m2/s2, mass in kg, and speed in m/s, your conversion factor is 1. It's all about the way the joule is defined in terms of the kilogram, the metre and the second. By definition, energy is expressed as above, and by definition, the dimensions are equivalent. The only way to reconcile these things is to set the constant of proportionality as unity. The "trick", is, I suppose, realizing that E isn't just kinetic energy, for example—it's all of the energy. This works as long as you're consistent with the reference frame; if you have gravitational potential energy such that h = 10, then you also have to calculate (relativistic) velocity with respect to that point—and (after considering all energies present in the system) the energies will work out as Einstein and Lorentz predicted. This formulation is valid for Newtonian and relativistic mechanics, but not necessarily for quantum mechanics. That's as deep as it gets. The bottom line is that we define the (SI) units in terms of each other, define the quantities (energy, etc.) in terms of the relativistic equations, and note that the dimensions of our equations are consistent. Last edited by Tristan Lall : 16-07-2006 at 18:56. |
#23
Tristan: I think you are still missing the elegance of Einsteins equation and the wonder of it coming out perfect.
1Kg of gasoline moving at 1M/S contains 1 Joule of energy. Ok, Imagine if burning gasoline at 1 atmosphere of air pressure released an amount of energy = M * speed of sound^2. Wouldnt it strike you as odd that equation happend to come out exactly right, when the amount of energy stored in a Kg of gasoline has nothing to do with the speed of sound through the air at sea level? Now that I think about it, I seem to recall there was something about the way Einstein derived his equation. You cannot accelerate matter to the speed of light, the amount of energy required to do so is infinite. I vaguely remember the connection here. Now Im going to have to go look it up. |
#24
My conclusion to all this discussion and the article is this:
There is only one constant, and that is change, which in itself varies. AHHHHHHHHHHHHHHH!!!!!!!!! NOTHING IS EVER GOING TO BE CONSTANT!!! ![]() ![]() 2 cents -Joe |
#25
Getting back to the units... How do we measure the speed of light? Well we have to use some units of distance and time, right? Not necessarily... We can also look at it from Maxwell's point of view consider only the electric and magnetic fields - which end up just using the permitivity and permeability constants of a vacuum. How are those defined? Teslas, meters, Amps, Newtons, Coulombs,... I bet I can throw some of those together and get Joules too. I guess I'm losing where I'm going here, but hopefully you get my drift. I don't want to sound like a know it all - because I really don't!! This is just some of my take on it and I sadly enjoy having this keep my up at night. |
#27
E=MC^2 is saying that a given amount of mass can be converted (translated? released...) into a specific amount of energy. When uranium fission occurs the uranium atoms change into lead atoms. Only one proton or neutron is lost in the process, but the mass of that one proton is where all the 'nuclear energy' comes from. That proton is gone, converted into pure energy. I thought I had an article that explained how Einstein's reasoning led him to the equation, but I cant find it. It might be something I read in a book. It had something to do with how matter warps space, and how matter cannot reach the speed of light. Thats why the equation comes out perfect with no correction constant needed. This is going to bug me until I can find the explaination. |
#28
When a nucleus of uranium (we'll use 235 for this example) becomes 236 and fissions, only the mass of the binding energy within the nucleus is lost and converted to energy. The products for this reaction are 3 neutrons (which may continue the reaction) and two products that account for the remaining mass (a common example would be Krypton 89 and Barium 144). However, even though the example shows that the mass in AMU's of a 236 uranium should equal that of (3 + 89 + 144), a small fraction of the mass is lost to energy (the energy between the 89, 144, and 3 that was once the 236 nucleus). |
#29
from Wikipedia: Quote:
#30
I've to agree with you. I'm at work, i really can't access anything except CD .But i do have the papers that explain E=mc^2. There is still a lot of research going on about this topic. I actually read the whole thread and now my mind is full of random questions too. But I'll try to make it as simple as possible and try not to raise anymore questions. I do agree the fact that there is a relationship between the speed of light and the gravity. Although our astronomy is strong enough to see the planets, but i don't think its strong enough to justify the relationship between gravity and light, especially in space, yet. Everything can have a constant speed in Vacuum, but what if there is a resistance in the Vacuum. Yes I'm referring to a black hole here. Light cannot escape Black hole, and thats a well known truth. now the question is does it changes it speed when it approaches the black hole. It might it might not. There is no way to prove it as of now. So the bottom line is Anything in Vacuum can go in a constant Speed. Even light can. But if theres a resistance in Vacuum (aka energy, I'm mainly talking about gravitational here) it can change. It might be a slightest change, but it does matter. Please try not to confuse it with other rays, because there is a lot of difference between the frequency of each and every ray, and we are talking about visible light here. And now heres something for you guys to think about. Theoretically it is possible for a human hand to cross a wall, only if the frequency of the particles in human hand is same as the wall or vise versa . |
| camera trouble,cant tell the green-light from regular white light | Nimmy | Programming | 26 | 14-01-2007 14:53 |
| Constant Force Springs - Data Sheets? | Ben Piecuch | Kit & Additional Hardware | 1 | 06-05-2004 19:00 |
| not quite sure...speed controller...spike. | tophq | Programming | 8 | 26-03-2004 13:43 |
| Getting the relays to stay constant | Lord Nerdlinger | Programming | 2 | 19-02-2004 10:17 |
| The physics of... soccer balls? | Gui Cavalcanti | Chit-Chat | 9 | 18-08-2002 16:19 |
