Go to Post when all else fails, try making the bot go slower - KenWittlief [more]
Unread 12-07-2006, 22:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
World's Fastest RC Car Contest
http://forums.radiocontrolzone.com/s...d.php?t=219036
So, what's the best way to win? (serious and on topic responses please).
Unread 12-07-2006, 23:37
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
Re: World's Fastest RC Car Contest
find the most efficient motor possible(gas or electric) and put it/them(if more than one is desired) onto the lightest, stiffest chassis possible.
Then make a body to go over it with a cockpit of some sort.
I might lean towards a magmotor of some sort or possibly one of these- http://robotcombat.com/marketplace_motors_perm.html
if you feel like going for an overkill solution.
Perm-132
72 V Performance
Peak efficiency: 88.6%
Peak power:*34.3hp
No-load angular velocity:* 3590 r/min
Stall current:* 1440A
Stall torque:*38500ozf·in
Oh, and find some FM radio gear with good range
Edit for random thought- Perhaps a flywheel based design would be worth considering. Spinning a 20-30lb flywheel to oh, say, 500mph(yes, insane, I agree) then transfering the power to some wheels and seeing what it does could be interesting.
Things to consider-
Wheelie bars
Very Low CG
front/4wd
how long it'll take a small motor to spin something that weighs 30lbs to 500mph
Team 675-Alumni
Near Chaos Robotics
Unread 12-07-2006, 23:41
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Radio control Porsche Carrera? or ferrari enzo... I forgot what was faster......
But seriously, traxxas sells cars that run around 60-70 mph stock.
It is seriously un believeable until you see them in person.
http://traxxas.com/products/promo/j33-n4t33-promo.htm
take 2 4-tecs motors and put them in the same car and gear them up 2x or even 1.5 (to compensate for the additional weight. and you will have one hella fast car.
Unread 13-07-2006, 12:13
run the trap!!!
Team Role: Human Player
Judging by the fact that they say it will be held at the "California Speedway drag strip in Fontana" I am assuming it is a dragrace?
Knowing what the track looks like is crucial to your design. The straightness of the track is a very important factor in determining the shape of your car. A dragster will not fair well in a slalom.
J&H Hobbies near my house was a long time record holder for the worlds fastest RC car.
The car they raced was a suped up model dragster.
They used electric motors, because they had better acceleration. The frame was made from carbon-fiber for rigidity. And it featured two super big wheels in the back for extra pushing traction.
Here's another modified racer I found online.
http://www.rccaraction.com/rc/articles/need_speed.asp
Realize however that these cars would fit easily into the size limits (40"), wasting a lot of space. Your best bet is in using bigger motors and more batteries.
Checking out the RobotMarketPlace is a good idea.
-Philip J. Fry
Unread 13-07-2006, 13:13
Worlds fastest RC car (with the following page of conditions and caviots!)
maybe they should change the competition to Worlds Fastest Toy Car?
The Mythbusters rigged up a full sized RC car with 6 rockets on it, went well over 200 mph
Unread 13-07-2006, 13:48
1902_Battery_SGT's Avatar
1902_Battery_SGT 1902_Battery_SGT is offline
100% charged 100% of the time
AKA: Scott
FRC #1902 (Exploding Bacon)
1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all
Send a message via AIM to 1902_Battery_SGT
i would lean in the direction of a single high powered wheel with two smaller wheels in front for steering. and then just lay a cockpit over it. that way it could be incredible light weight but still stable.
Unread 13-07-2006, 13:51
AKA: Scott
funny you should mention that. the first rule says.
Wheel-driven vehicles only. Vehicles powered by thrust (jet, rocket, propeller, etc.) are not allowed. Turbine power is allowed only if the turbine is used to drive the wheels, not for thrust.
Unread 13-07-2006, 14:58
thats what I was referring to, the page of requirments and caviots that go along with the 'World's Fastest RC Car Contest' title
you cant claim to be the best / fastest /strongest... in the world, if you slap a bunch of restrictions on the contest.
Unread 14-07-2006, 05:25
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
The fastest electric RC car that I know of did around 110 mph. Some 24 batteries driving a 2 turn brushless motor.
15,000 RPM at the wheels!!!!
http://images.google.com/imgres?imgu...icial%26sa%3DN
Unread 14-07-2006, 13:30
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Perm-132
72 V Performance
Peak power:*34.3hp
1440 Amps at stall - Yikes!! Better use some automotive starter cables.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 14-07-2006, 13:49
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Nitro engines are what will probably win, they produce more power per unit weight than the electric motors, have all their torque at the top end where it's needed in high-speed applications, and don't need a huge battery pack to power it. If one is looking for RPMs at the wheels... nitro engines can run easily in excess of 20,000rpm producing 5hp or more with around 1lb of weight. Use, say... a 3 spd automatic transmission plus another gear-up since we don't care about acceleration too much, run 2 or more motors mated to an AWD chassis, and the car would be much faster than any electric.
Oh yea, a good aero package would be defintely needed to keep the thing stable.
Unread 14-07-2006, 13:53
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
There use to be a video floating around with a car attached to a sting and it would go around a circular track at WAY over 200mph...I'm not sure if it was the mythbusters one of not.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 14-07-2006, 14:47
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
http://youtube.com/watch?v=e1YYfwaiQ...est%20rc%20car
Here it is.
http://youtube.com/watch?v=QADldgFHv...c%20car%20ramp
This ones pretty fast
Also, heres the worlds fastest: http://www.wired.com/wired/archive/11.03/speed.html
P.S. Sanddrag, if you find this to be an off topic reply, then please tell me and I will remove it.
World's Worst Nita Games/Trivia 206 11-02-2013 15:18
World's Ugliest Robot Race V.2 Conor Ryan Chit-Chat 14 07-10-2005 05:23
World's Fastest R/C Car, anyone? Billfred General Forum 75 05-08-2005 12:56
World's Tallest Hockey Player D.J. Fluck Chit-Chat 10 17-11-2002 16:37
Fastest way to lower the bridge? archiver 2001 8 23-06-2002 22:32
