Re: Axel Diameters
If you use Grade 8 bolts, 3/8" works fine.
Re: Axel Diameters
1293's used 3/8" threaded rod for two seasons with no complaints at all. (After some personal experience with my omnidrive project, however, I'd be inclined to make the switch to bolts.)
Re: Axel Diameters
I prefer 1/2" shaft, it is smaller and saves that precious weight.
Re: Axel Diameters
Re: Axel Diameters
Re: Axel Diameters
Re: Axel Diameters
Re: Axel Diameters
If you use 3/8, make sure it is steel.
If you go to 1/2, you can use aluminum - this is our typical shaft size and material. |
#9
Re: Axel Diameters
3/8" shaft must be supported on both sides, you can probably do without the extra support with 1/2". In 2005 we used 3/8" shaft with the skyway wheels, and slowly the axles bent upwards. They would be fine if it was just our robot driving around on the flat surface, but it had to content with other robots weight some of the times, and being leaned back onto 2 wheels for getting it up onto the cart, etc... Luckily, we just had to undo some bolts, take off some shaft-locks, and slide out the old axles, put new ones in, put wheel and shaft locks on, tension up the chain, and tighten the bolts back up.
#10
Re: Axel Diameters
I highly recommend using 3/8" grade 8 bolts with the KOP frame and Skyway wheels.
#11
Re: Axel Diameters
we used the high traction robot wheels and they work very good with our design. the only thing im having trouble wiht is trying to figure out how much bigger the hole needs to be where the shaft goes into the side plates
#12
Re: Axel Diameters
Re: Axel Diameters
233 uses 1/4" diameter axles
#14
Re: Axel Diameters
Do yourself a favor and always use grade 5 or 8 bolts or something better anywhere you can. Forget threaded rod and any of that mystery metal stuff, unless it is very large.
Although heavy, we've more often than not used 5/8" driven axles with bearings on each end. 4 years, never a single drivetrain failure. This is using regular shaft with a keyway, which is not, to my knowledge, heat treated in any way. |
#15
Re: Axel Diameters
I would think that 3/8" grade 8 bolts would work fine for most FRC robot drive axles. |
| Mounting encoder/cutting 12 in axel | intellec7 | FIRST Tech Challenge | 8 | 12-04-2006 12:55 |
| Live axel on kit skyways? | Bill_Hancoc | Technical Discussion | 10 | 16-03-2006 17:38 |
| Attatching an axel to a wheel | Zoheb N | Technical Discussion | 36 | 12-12-2005 13:43 |
| Crazy Frog - Axel F | Elgin Clock | Chit-Chat | 23 | 24-09-2005 22:04 |
