Go to Post Roses are red/Violets are blue/I'll write a poem/Once build season's over. - Taylor [more]
Unread 13-07-2006, 16:18
Billfred's Avatar
Billfred Billfred is offline
Re: Axel Diameters
1293's used 3/8" threaded rod for two seasons with no complaints at all. (After some personal experience with my omnidrive project, however, I'd be inclined to make the switch to bolts.)
Unread 13-07-2006, 16:38
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Axel Diameters
I prefer 1/2" shaft, it is smaller and saves that precious weight.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 13-07-2006, 17:15
Billfred's Avatar
Re: Axel Diameters
Isn't 3/8 less than 1/2?
Unread 13-07-2006, 17:23
FRC #1405
Re: Axel Diameters
minor details.
Unread 13-07-2006, 17:28
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Axel Diameters
Only in metric...
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 14-07-2006, 13:06
Booger's Avatar
Booger Booger is offline
FRC #0637
Booger will become famous soon enough
Re: Axel Diameters
hahhaha thats what i was thinking
Collars up!
637
Unread 14-07-2006, 13:20
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Re: Axel Diameters
If you use 3/8, make sure it is steel.
If you go to 1/2, you can use aluminum - this is our typical shaft size and material.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 14-07-2006, 16:23
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Re: Axel Diameters
3/8" shaft must be supported on both sides, you can probably do without the extra support with 1/2". In 2005 we used 3/8" shaft with the skyway wheels, and slowly the axles bent upwards. They would be fine if it was just our robot driving around on the flat surface, but it had to content with other robots weight some of the times, and being leaned back onto 2 wheels for getting it up onto the cart, etc... Luckily, we just had to undo some bolts, take off some shaft-locks, and slide out the old axles, put new ones in, put wheel and shaft locks on, tension up the chain, and tighten the bolts back up.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 14-07-2006, 17:34
Gdeaver Gdeaver is offline
FRC #1640
Re: Axel Diameters
I highly recommend using 3/8" grade 8 bolts with the KOP frame and Skyway wheels.
Unread 17-07-2006, 11:52
Booger's Avatar
FRC #0637
Re: Axel Diameters
we used the high traction robot wheels and they work very good with our design. the only thing im having trouble wiht is trying to figure out how much bigger the hole needs to be where the shaft goes into the side plates
Collars up!
637
Unread 17-07-2006, 19:14
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Axel Diameters
If it's a powered axle in bearings, you'll need to bore press fit holes large enough for the bearing outer diameter. If you're using a dead axle and you're not intent on being too precise (which seems to be the case), you ought to be fine by drilling out the hole with a drill bit the same diameter as your axle and then opening it up slowly by hand using a deburring tool or the like.
--Madison--
...down at the Ozdust!
Unread 18-07-2006, 12:01
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
Re: Axel Diameters
233 uses 1/4" diameter axles
See Ya
Unread 25-07-2006, 19:20
Dick Linn's Avatar
no team (Synergy)
Re: Axel Diameters
Do yourself a favor and always use grade 5 or 8 bolts or something better anywhere you can. Forget threaded rod and any of that mystery metal stuff, unless it is very large.
Although heavy, we've more often than not used 5/8" driven axles with bearings on each end. 4 years, never a single drivetrain failure. This is using regular shaft with a keyway, which is not, to my knowledge, heat treated in any way.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Mounting encoder/cutting 12 in axel intellec7 FIRST Tech Challenge 8 12-04-2006 12:55
Live axel on kit skyways? Bill_Hancoc Technical Discussion 10 16-03-2006 17:38
Attatching an axel to a wheel Zoheb N Technical Discussion 36 12-12-2005 13:43
Crazy Frog - Axel F Elgin Clock Chit-Chat 23 24-09-2005 22:04
