Go to Post The rules also never explicitly say that I can't park a Boeing 747 right in the middle of the play field and use it as an obstacle for the other alliance. But after a little thought, something tells me that I probably should not do it. - dlavery [more]
Unread 17-07-2006, 11:52
Booger's Avatar
Booger Booger is offline
FRC #0637
Booger will become famous soon enough
Re: Axel Diameters
we used the high traction robot wheels and they work very good with our design. the only thing im having trouble wiht is trying to figure out how much bigger the hole needs to be where the shaft goes into the side plates
Collars up!
637
Unread 17-07-2006, 19:14
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Axel Diameters
If it's a powered axle in bearings, you'll need to bore press fit holes large enough for the bearing outer diameter. If you're using a dead axle and you're not intent on being too precise (which seems to be the case), you ought to be fine by drilling out the hole with a drill bit the same diameter as your axle and then opening it up slowly by hand using a deburring tool or the like.
--Madison--
...down at the Ozdust!
Unread 18-07-2006, 12:01
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
Re: Axel Diameters
233 uses 1/4" diameter axles
See Ya
Unread 25-07-2006, 19:20
Dick Linn's Avatar
no team (Synergy)
Re: Axel Diameters
Do yourself a favor and always use grade 5 or 8 bolts or something better anywhere you can. Forget threaded rod and any of that mystery metal stuff, unless it is very large.
Although heavy, we've more often than not used 5/8" driven axles with bearings on each end. 4 years, never a single drivetrain failure. This is using regular shaft with a keyway, which is not, to my knowledge, heat treated in any way.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Mounting encoder/cutting 12 in axel intellec7 FIRST Tech Challenge 8 12-04-2006 12:55
Live axel on kit skyways? Bill_Hancoc Technical Discussion 10 16-03-2006 17:38
Attatching an axel to a wheel Zoheb N Technical Discussion 36 12-12-2005 13:43
Crazy Frog - Axel F Elgin Clock Chit-Chat 23 24-09-2005 22:04
