Go to Post I have also emailed Dean Kamen for more information regarding our team and its future, as I may have confused myself a bit. - ExcuseBoy [more]
Unread 17-07-2006, 20:14
Eric W. Jones's Avatar
Eric W. Jones Eric W. Jones is offline
Rack & Roll, baby!
FRC #1646 (Precision Guessworks)
Eric W. Jones will become famous soon enoughEric W. Jones will become famous soon enough
Using auxiliary joystick buttons with IFI controller.
Does the FIRST controller recognize the auxiallry buttons on the joysticks provided in the kit; and, if so, what are they referred to in the code?
Unread 17-07-2006, 20:26
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
Re: Using auxiliary joystick buttons with IFI controller.
Are you talking about the trigger and top buttons?
If so, they're recognized by the port of the joystick which they're on. For example if you wanted to use the trigger button on the joystick plugged into port 1, you use p1_sw_trig , likewise the top button would be p1_sw_top .
Let me know if this helps.
-Kristian
EDIT: Whoops, I misread your post, you said auxiliary. Use p1_sw_aux or p1_sw_aux2 [just change the number of the port to the one you need].
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 17-07-2006, 20:41
Rack & Roll, baby!
This is very helpful. Thank you.
Unread 17-07-2006, 23:33
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Also, the various positions of the hat switch (the big round clicky thing) manifest themselves as different analog values on either the p1_aux or p1_wheel variables (can't remember which).
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 03-12-2006, 18:36
robind robind is offline
FRC #0675
robind is an unknown quantity at this point
Does anyone have more details on what the values are for the hat switch?
Unread 03-12-2006, 19:21
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
From ifi_aliases.h
PHP Code:
 *---------- Aliases for each OI analog input ---------------------------------------------------------
 *  Below are aliases for the analog inputs located on the Operator Interface.
#define p1_y        rxdata.oi_analog01
#define p2_y        rxdata.oi_analog02
#define p3_y        rxdata.oi_analog03
#define p4_y        rxdata.oi_analog04
#define p1_x        rxdata.oi_analog05
#define p2_x        rxdata.oi_analog06
#define p3_x        rxdata.oi_analog07
#define p4_x        rxdata.oi_analog08
#define p1_wheel    rxdata.oi_analog09
#define p2_wheel    rxdata.oi_analog10
#define p3_wheel    rxdata.oi_analog11
#define p4_wheel    rxdata.oi_analog12
#define p1_aux      rxdata.oi_analog13
#define p2_aux      rxdata.oi_analog14
#define p3_aux      rxdata.oi_analog15
#define p4_aux      rxdata.oi_analog16
 *---------- Aliases for each OI switch input ---------------------------------------------------------
 *  Below are aliases for the digital inputs located on the Operator Interface.
 *  Ports 1 & 3 have their inputs duplicated in ports 4 & 2 respectively.  The
 *  inputs from ports 1 & 3 may be disabled via the 'Disable' dip switch
 *  located on the Operator Interface.  See Users Manual for details.
#define p1_sw_trig  rxdata.oi_swA_byte.bitselect.bit0 /* Joystick Trigger Button, same as Port4 pin5 */
#define p1_sw_top   rxdata.oi_swA_byte.bitselect.bit1 /* Joystick Top Button,     same as Port4 pin8 */
#define p1_sw_aux1  rxdata.oi_swA_byte.bitselect.bit2 /* Aux input,               same as Port4 pin9 */
#define p1_sw_aux2  rxdata.oi_swA_byte.bitselect.bit3 /* Aux input,               same as Port4 pin15*/
#define p3_sw_trig  rxdata.oi_swA_byte.bitselect.bit4 /* Joystick Trigger Button, same as Port2 pin5 */
#define p3_sw_top   rxdata.oi_swA_byte.bitselect.bit5 /* Joystick Top Button,     same as Port2 pin8 */
#define p3_sw_aux1  rxdata.oi_swA_byte.bitselect.bit6 /* Aux input,               same as Port2 pin9 */
#define p3_sw_aux2  rxdata.oi_swA_byte.bitselect.bit7 /* Aux input,               same as Port2 pin15*/
#define p2_sw_trig  rxdata.oi_swB_byte.bitselect.bit0 /* Joystick Trigger Button*/
#define p2_sw_top   rxdata.oi_swB_byte.bitselect.bit1 /* Joystick Top Button*/
#define p2_sw_aux1  rxdata.oi_swB_byte.bitselect.bit2 /* Aux input*/
#define p2_sw_aux2  rxdata.oi_swB_byte.bitselect.bit3 /* Aux input*/
#define p4_sw_trig  rxdata.oi_swB_byte.bitselect.bit4 /* Joystick Trigger Button*/
#define p4_sw_top   rxdata.oi_swB_byte.bitselect.bit5 /* Joystick Top Button*/
#define p4_sw_aux1  rxdata.oi_swB_byte.bitselect.bit6 /* Aux input*/
#define p4_sw_aux2  rxdata.oi_swB_byte.bitselect.bit7 /* Aux input*/
"_wheel" makes sense but have it output all the values with a simple printf and use the joystick (press buttons to change values, etc) so you can determine which variable it is.
Unread 03-12-2006, 19:24
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
This is not correct. "_wheel" is for the large wheel on the left hand side of the CH Flightstick (ie: not the trim wheels). I am not certain what the hat corresponds to, but my best guess would be the aux's, or the second joystick.
[edit]I just realized that you are talking about new sticks and I am talking about old sticks. See Astronouth's post below me for information about the new joysticks.[/edit]
You see, back in the day, two joysticks could be hooked to each gameport port. Some hardware manufacturers, rather than building an entire second joystick, just put in some circuitry to send "full up/down/left/right" instead of the analog values. This let you map the second joystick to a D-pad, for instance.
However, on the IFI implementation of the Gameport, the "_wheel" variable uses one of the analog axes of the second joystick, and the "_aux" variable the other analog axis. This still leaves the two remaining digital variables of "_aux1" and "_aux2". It is possible that the up/down or left/right gets mapped "full up/down" to "_aux" and the other is mapped to "_aux1" and "_aux2".
Sorry if my explanation now doesn't make a tremendous amount of sense. I am going to be writing all of this up much more clearly before build season.
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Ok, I won't chew you out for not searching, since I had to dig deep to find them, and I knew what I was looking for.
See http://www.chiefdelphi.com/forums/sh...655#post212681
Just be warned that that was back in 2004, when they first came out. There's a good chance they've changed, knowing how good of joysticks they are.
Unread 03-12-2006, 19:33
Back after 4 years off
FRC #5279
Download the Dash board from ifi and use that to check the buttons.
Also remember that the even ports have pins to use for the switches of the odd port on the opposite side, so if you put in custom switches makes sure you aren't using them for more than one thing. Programmers should know the OI reference guide and the RC reference guide and the victor reference guide and every thing about the cmu-cam
Those documents will save you hours during build season, and are extremely important for trouble shooting electronics and programming.
James
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 03-12-2006, 22:26
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Hey!
I just recently too just found out the values for the p1_wheel. If you are still interested send me a private message. That link you sent seems helpful if you noe Base 2 (binary). But i noe them in Base10 (normal decimal). let me noe.
Using IFI Controller witout Operator System 703pascal Programming 20 16-06-2007 22:10
Programming motors with joystick buttons TMHStitans Programming 5 21-03-2005 21:07
Victors controlled with joystick Buttons JamesBrown Programming 2 18-02-2005 23:39
Using the extra buttons on the joystick. Code\\Pilot Programming 7 04-12-2004 19:30
problem with joystick buttons (top left one) Richomundo Programming 5 15-02-2004 17:16
