Go to Post I love it when someone tells me I can't do something. - dlavery [more]
Unread 18-07-2006, 14:25
Erro's Avatar
Erro Erro is offline
Chairman's Team Student Leader
AKA: Will H.
FRC #0365 (Miracle of Engineering)
Erro is an unknown quantity at this point
Question Autodesk Inventor and downloads
Hello all. I am working with Inventor and have run across a problem. I would like to use the pre-generated models for Bosch aluminum stock from the Bosch website, but am having trouble importing it. I have saved it to my desktop in the appropriate Inventor format (.sat) but cannot open it. Windows keeps telling me that it doesn't recognize the format and needs to know what program created it, so I try to tell it that Inventor created it, but it won't listen. Any recommendations would be very much appreciated. Anything that works- other sites, formats, etc.
Enthusiastic (and often exasperated ) former captain of MOE 365 Chairman's Award Presentation Team...
Willy the Wandering Turtle (don't ask me where I picked that one up- it's a long story)...
Check out the blog at http://politicalhumorscience.blogspot.com
Unread 18-07-2006, 15:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Autodesk Inventor and downloads
try step or iges formats.
Unread 19-07-2006, 11:20
Erro's Avatar
AKA: Will H.
Thanks. I tried .igs and that worked.
Unread 16-08-2006, 16:36
Erro's Avatar
AKA: Will H.
Re: Autodesk Inventor and lack of tech support
Hello again. Yet more problems with Inventor have occurred. Every time I try to open a part or assembly, Inventor simply closes down and gives me an error report to fill out. I have no idea why it does this. I have updated it with the three service packs offered by Autodesk on their website (although admittedly the problem did not begin until that point). Autodesk's tech support is only for those who subscribe to it, so does anyone know if FIRST gets free subscriptions? Thanks for any help.
Unread 16-08-2006, 16:43
REVving up for a new season
FRC #2848 (All-sparks)
Did you receive any errors when you installed inventor? What you are talking about sounds like a corrupt install. Are you opening files from inside inventor or are you opening them from windows explorer?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 16-08-2006, 17:03
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
I have a similar problem. After I open up Inventor, if a blank part file template is the first thing I open, it closes and does the error report. If I open up another file and close it, I can then open a part file and use the program with no problems.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 16-08-2006, 17:33
Erro's Avatar
AKA: Will H.
I am opening the files through Inventor, not Explorer. A corrupt install sounds possible (even likely), but I hope it isn't. Even if I open a blank or saved part it still shuts down. I contacted the Autodesk registration number, and they informed me that there is a number for FIRST teams, but they didn't have it. A contact at Autodesk was supposed to be provided in the package for all teams, but ours is taking some time to be located (I don't have the package, but a mentor does). Once I find the contact I will post it here for the general edification of the public. In the meantime, all suggestions are welcome.
Unread 16-08-2006, 18:35
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
I am forwarding the Autodesk FAQ from Streamline to your email. According to that document the contact for Inventor Installation Questions is John Elliott (503) 692-8367.
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Unread 16-08-2006, 18:48
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
That's interesting. I've seen the same problem occur on Inventor 11 Professional SP1 (Student Edition), build 312b. This was using Inventor's own "Open" dialog box, which appears when you open Inventor directly (i.e. without double-clicking an .ipt file, etc.).
Unread 16-08-2006, 22:11
7
FRC #1712 (Dawgma)
I would also guess that it's a corrupt install.
What would I do about a corrupt install--uninstall and reinstall? Does the install problem occur because of a problem with the copied CD, or with the one instance my installation?
Either way, it's probably easier to keep using the program the way I do. If I continue to do this, do you know if the problem would cause damage to the software, or would it be safe?
Unread 17-08-2006, 00:57
CraigHickman
Posts: n/a
I had the same issue. I'll bet you're running on a multiple user system, and using inventor from a non admin user. Autodesk has a fix for this on their site, if you poke around. I forget exactly where it is, but if you search their site for user related things, you should find the patch that fixes it.
Unread 17-08-2006, 01:36
I'm running as a member of the administrators group*, under the same account that installed the program, and yet I still experience this issue. But it is a multi-user system (like every default Windows NT 5.x installation).
Also, if you want to rule out a corrupt installation, Inventor has a repair install option (look in Add/Remove Programs and select "Change"). Give that a shot, and see what happens. (But I haven't bothered to run a repair install, not wanting to mess up all of my configurations.)
*I know, you're not supposed to do this. But since I don't have an AD domain set up, I don't have access to the GPOs and other configuration options that would make this painless to live with day-to-day.
Unread 17-08-2006, 11:13
gabrielse's Avatar
gabrielse gabrielse is offline
FRC #1748 (Lab Rats)
gabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to behold
We had the same problem. We even wiped the hard drive and reinstalled. We also installed all the service packs. Finally, we had to give up. Thankfully, if we opened files from explorer it usually worked alright. The problem seemed to be related to our video card. Check to see if your video card is supported.
Unread 17-08-2006, 19:25
Erro's Avatar
AKA: Will H.
Thanks for all the help guys. I talked to John Elliott, the installation contact, and it turns out that my chipset on my laptop was not supported. He walked me through a way to use a generic emulator to make it work a little, but I am going to get a copy of Inventor 11, which does support my chipset.
**FIRST EMAIL**/Autodesk Software Donation, Inventor Training and Awards Information Beth Sweet FIRST E-Mail Blast Archive 3 05-10-2005 23:34
FRC 2005 Drivetrain and Transmission Parts on Autodesk Inventor 7 KrazyRoadster Inventor 1 23-01-2005 20:29
**FIRST EMAIL**/Log-In and Dial-In Information for Autodesk Inventor Training Jan.5th dez250 FIRST E-Mail Blast Archive 0 04-01-2005 14:46
**FIRST EMAIL**/Autodesk Inventor Training Date, Time and Access Information Rich Wong FIRST E-Mail Blast Archive 2 16-12-2004 19:15
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
