Go to Post I love how the people of Chief Delphi can turn a spam post into a somewhat non-timewasting thread. Either way, congrats CD and thanks for this ;) - logank013 [more]
Unread 18-07-2006, 15:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Robots tilt
I'm not really sure how angled wheels would provide easier turning (I have seen teams do this for some odd reason I've yet to understand), but in a 6wd setup, many teams choose to lower the center wheel so that there can be at most 4 wheels on the ground at any given time. I've found 3/16" offset to be sufficient. Personally, the rocking (tilting) with 3/16" offset was a bit of an annoyance for me. But this was for the Triple Play game where we were trying to place a tetra with a long arm. I'd split the difference between 3/16" and 1/8" and set it at 5/32" (if you keep tolerance on these sort of things to that small). Of course it somewhat depends on what tires/tread you are running. Anything over 3/16" I think would be excessive and anything below 1/8" would be too small.
Unread 18-07-2006, 15:42
Booger's Avatar
Booger Booger is offline
FRC #0637
Booger will become famous soon enough
Re: Robots tilt
no no no...Arefin Bari had it right. Im not tilting the wheels im lowering the middle wheel so the robot can tilt
Collars up!
637
Unread 18-07-2006, 17:57
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Robots tilt
We have done this for the past two years with great success. Our
2004 robot had a four wheel design with 4WD, and we had many problems with turning. Our 2005 and 2006 robots
had 6WD with the center wheel slightly lower than our two outer wheels. If you use a pneumatic wheel for the center, you can adjust how offset the center wheel is.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
pan & tilt errors itzrobz Programming 2 19-02-2006 19:12
Grabbing Tilt Angle? crossedheart Programming 7 09-02-2006 03:08
CMUCam2 GUI Tilt Question Idaman323 Programming 3 27-01-2006 02:01
Tilt Troubles Mumford 406 Programming 4 29-03-2005 22:19
Weight needed to tilt bridge... archiver 2001 4 23-06-2002 23:43
