| Thread Tools |
Rating:
Display Modes |
#106
Re: One upping Dave: A Diet Coke and Mentos Rocket!
there have been great improvements in vehicle safety both in the seatbelt construction and latching and in the cars themselves (we can thank the hundreds of crash dummies for that). Seat belts rarely break in accidents and when they do, many times they have done their job and protected the person from the initial impact of the accident. My brother-in-law was also in an accident were his seatbelt broke and he was thrown from the car (Blazer). But the belt broke after the Blazer rolled four times, If he had not been wearing the belt, he probably wouldn't have been alive to be thrown from the vehicle. By the time he was thrown the speed was reduced to a point where could survive the ejection. Buckle Up Everyone! Especially if you are driving by the neighborhoods of Art, Elgin and Dylan when they are experimenting with Diet Coke and Mentos! |
#107
Maybe someone should start putting seat belts on those DC/M rockets people are working on.
#108
Interesting Idea would be a steal reinforced bathtub (filled with water) and some Francium ![]() ***200th Post*** ![]() |
#111
I don't know if this has been suggested. It trades power for control. You may not get the bottle to fly 50 ft, but maybe 15 feet straight up reliably is a nice trade-off.
Summary: (a) suspend 5 mentos inside the bottle above the soda using a paper clip threaded through holes in the mentos. See here: http://www.youtube.com/watch?v=GAHGz...0coke%20mentos (b) Use a cork to hold the pressure until it builds. (c) Construct a rudimentary launch platform from another 2 liter bottle so it launches straight up. Details: (1) Buy a cork that will fit firmly into the mouth of a 2 liter diet coke bottle. They have these at Michaels for <$2 for 4 of them. (2) Create a launcher. Take an empty 2 liter bottle. Remove the label and soda. Use a box cutter or exacto knife to cut the bottle in half with a clean straight cut. 1/2 inch above the halfway point is actually perfect (yes above). Throw out the top of the bottle. The bottom will be your launcher. (You will put the corked full bottle inside it and turn the whole assembly upside down to launch.) (3) Prepare mentos. Take four mentos (5 is slightly better but dips into the soda and causes permature mixing thus ruining the launch.) Poke a hole through the centers of the mentos. I use a large thick paper clip or very thin nail for this because a normal clip just bends. String the four mentos through a small paper clip and then press the end of the clip into the bottom (inside) of the cork. The mentos need to be flush against the cork or they will mix with the soda too early. (4) Cork the rocket. Open a new Diet Coke 2 liter bottle (Actual Diet Coke Brand is reported as the best, adn Dieat Coke beats non-diet becuase it's less sticky to clean up). Push the cork in as tightly as possible being careful not to crush the bottle and make sure NOT to let the mentos hit the soda!! Take the launcher and place it over the top of the rocket. You can get a little airtight seal here but don't worry if not - the main importance of the launcher is to hold the bottle upright. (5) Turn the whole thing over (do not shake), and place upside down on the pavement and immediately back away. Don't hesitate because it can go off pretty fast. The rocket should shoot upward maybe 15 feet or so. The trick is getting the cork as tight as possible. A rubber stopper might be better than a cork but I didn't try that. Then again if too tight you're back to the problem with the cap (not coming off until you destroy it). A 20 oz bottle might work even better, less weight, but I didn't try that. Also try a few more mentos and dump a little soda out first - more air space, more released gas should cause a faster and more explosive release??? It seems fairly safe, especially compared to slamming the capped bottle down, but use caution, consider eye protection, and of course avoid young kids around. It can still go at odd angles. Have fun. |
#112
http://blog.sciam.com/index.php?titl...&c=1&tb=1&pb=1 |
#114
if surface area is the trigger then confectionery sugar, charcoal from an aquarium filter, or talcum powder might work better.
#117
I imagine Diet works better because its much lighter than regular, so the same amount of CO2 "thrust" causes further projections.
#118
Confectionery sugar will most likely turn into sticky blobs Charcoal is nasty Talcum powder (at least the real kind) is a carcinogen! But if wax works you could probably just drop a candle in the coke and then re-use it, which would cut costs and not be sticky. |
#119
the charcoal used in filters has a very fine and grainy surface - thats why it makes a great filter, there is so much exposed surface area in a small handfull of the stuff. Nobody drinks this stuff off the driveway after the launch, do they?! you dont scoop it back in the bottle and put it back in the fridge (I hope) ![]() |
#120
What I meant was that charcoal would make a would make worse mess (black) than Mentos. |
| I think these guys have just one-upped Dave... | geeknerd99 | Chit-Chat | 11 | 22-11-2006 19:18 |
| pic: Mentors and Mentos | MissInformation | Extra Discussion | 33 | 05-06-2006 08:33 |
| One-upping JVN. | Joe Matt | Chit-Chat | 13 | 06-09-2005 23:47 |
| pic: Big Mike and Dave and Brandon | dlavery | Extra Discussion | 11 | 27-04-2005 10:43 |
| Former FIRST student and mentor dies in a tragic rocket attack in Iraq today. | Munkaboo | General Forum | 48 | 19-04-2005 12:21 |
