Re: Robots tilt
25 Doesnt lower their middle wheels at all....
Re: Robots tilt
This year we lower the center wheels about a quarter inch, but also ran a lower pressure in the outer wheels.
Re: Robots tilt
60 and 254 both did this for their 2004 machines. Not sure if they still use it but their current drive systems are similar.
Re: Robots tilt
Andy B. |
Re: Robots tilt
03 short side 04 Long side, without full use of entire side due to step pop up mechanism. 05 long side 06 long side Edit: Source Last edited by henryBsick : 19-07-2006 at 00:29. |
Re: Robots tilt
i put a 1/4" space between the outside and inside wheels is that enough/too much?
#7
Re: Robots tilt
This situation REALLY depends on the robot's Center of Gravity (Cg). Again, generally speaking, a robot with a higher Cg needs more "tilt" difference between the vertical location of the outside wheels and the inside wheel. Robots with a lower Cg will turn OK without a difference, but robots with higher Cg will jump and wobble as they try to turn with no difference. AB |
#8
Re: Robots tilt
Now that we understand what you're trying to ask, here's what you'd find if you searched for the answers...
http://www.chiefdelphi.com/forums/sh...ad.php?t=42741 BEN |
| pan & tilt errors | itzrobz | Programming | 2 | 19-02-2006 19:12 |
| Grabbing Tilt Angle? | crossedheart | Programming | 7 | 09-02-2006 03:08 |
| CMUCam2 GUI Tilt Question | Idaman323 | Programming | 3 | 27-01-2006 02:01 |
| Tilt Troubles | Mumford 406 | Programming | 4 | 29-03-2005 22:19 |
| Weight needed to tilt bridge... | archiver | 2001 | 4 | 23-06-2002 23:43 |
