Go to Post Unfortunately, you cannot always tell when some things are jokes on forums, because we only can rely on text and a limited number of smilies. - artdutra04 [more]
Unread 19-07-2006, 00:10
Andy Baker Andy Baker is online now
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: Robots tilt
Originally Posted by Big Mike
25 Doesnt lower their middle wheels at all....
That's because 25 runs their wheels along the short side of the robot. For robots who run theirs along the long side of the robot, then I suggest a 0.125" to 0.20" drop in the center wheel.
Andy B.
Unread 19-07-2006, 00:22
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: Robots tilt
Andy B.
Andy, I agree with you for their 2003 year, but...
03 short side
04 Long side, without full use of entire side due to step pop up mechanism.
05 long side
06 long side
Edit:
Source
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 19-07-2006, 08:32
Booger's Avatar
Booger Booger is offline
FRC #0637
Booger will become famous soon enough
Re: Robots tilt
i put a 1/4" space between the outside and inside wheels is that enough/too much?
Collars up!
637
Unread 19-07-2006, 08:41
Re: Robots tilt
03 short side
05 long side
06 long side
Edit:
Source
Yes, I spoke too soon. Big Mike AIMed me with a correction also.
In a general sense, I would suggest less. 0.2" should be fine for most cases.
This situation REALLY depends on the robot's Center of Gravity (Cg). Again, generally speaking, a robot with a higher Cg needs more "tilt" difference between the vertical location of the outside wheels and the inside wheel. Robots with a lower Cg will turn OK without a difference, but robots with higher Cg will jump and wobble as they try to turn with no difference.
AB
Unread 19-07-2006, 10:01
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Robots tilt
Now that we understand what you're trying to ask, here's what you'd find if you searched for the answers...
http://www.chiefdelphi.com/forums/sh...ad.php?t=42741
BEN
pan & tilt errors itzrobz Programming 2 19-02-2006 19:12
Grabbing Tilt Angle? crossedheart Programming 7 09-02-2006 03:08
CMUCam2 GUI Tilt Question Idaman323 Programming 3 27-01-2006 02:01
Tilt Troubles Mumford 406 Programming 4 29-03-2005 22:19
Weight needed to tilt bridge... archiver 2001 4 23-06-2002 23:43
