Go to Post Im very proud of my kids, and my whole team, the passion and emotion here is what FIRST is all about :) - Kims Robot [more]
Unread 19-07-2006, 03:51
maclaren maclaren is offline
AKA: Dexter
FRC #0997 (Spartan Robotics)
maclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of light
Main Battery Cables
We are planning on making a charging station for our batteries so that they are all organized and such. But we need more of the battery connectors. I know that they are made by Anderson power products ad know that you can get the housings and the contacts at various electrical suppliers what I was wondering is if any knows where to get the pre-assembled ones just the ones that they send in the kit of parts?
Unread 19-07-2006, 08:25
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: Main Battery Cables
If you are using them on chargers, it will likely be much easier to get the 10 Ga. contact and use those. Connecting to the KOP wires for small charging cables isn't easy.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 19-07-2006, 09:33
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
While not identical to the KOP ones, you can buy something similar from BG Micro. I believe the part number was CAB2119. The cable is 4' long with an Anderson connector on both ends.
Mike
Unread 19-07-2006, 12:20
in between teams
AKA: Luke Van Oort
Linky
Searching always helps....
As to Andersons on chargers, it's really nice. 587's been doing it for years and really saves time, and is quite a bit safer. (Assuming you connect the charger wire and the Anderson with a proper connector and wrap the connection with electrical tape)
Team 1219: 2009 - Mentor
Unread 19-07-2006, 13:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Robot MarketPlace and Powerwerx have the housings and contacts. The preassembled ones in the FIRST kit are done special for FIRST I believe. You shouldn't use them anyway, the wire is junky.
Unread 19-07-2006, 13:23
REVving up for a new season
FRC #2848 (All-sparks)
Originally Posted by lukevanoort
[(Assuming you connect the charger wire and the Anderson with a proper connector and wrap the connection with electrical tape)
This is the bare minimum solution.
Ideal - open the chargers up and replace the charging cords where they connect to the board. They are just push on connectors. Some modification to the case is necessary to run the larger gage wire through it.
Next best thing - cut the leads of the charger as close to the charger as you can and make a connection using a solder connector covered with heat shrink tubing.
Next Next best thing - same as above but you use a crimp butt connector and electrical tape
Bare minimum - splice the Anderson connectors onto the the long leads where needed and cover with heat shrink tube or electrical tape.
If you are going to convert one of the chargers to use the Anderson connectors please do it correctly. DO not just crimp the alligator clips to the wire and electrical tape them. While you are dealing with a smart charger it is still 6amps DC, and should not be taken lightly.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 19-07-2006, 15:05
AKA: Dexter
Thanks Mike Bortfeldt that cable looks like it is exactly what I need.
We aren't actually planning on modifying the chargers that first provided. We are actually planning on making the charging station from scratch. So we will be purchasing a transformer, rectifier, voltmeter read out and designing and building intelligent charging circuitry. We plan on being able to attach 8 main batteries and a few of the small backup batteries to the charing station. We are also planning on adding in some built in power sources with terminal blocks so that we can run experiments and such off of them.
Our current charging setup is the car chargers with the app cables attached to them and the problem is that students will forget to plug them in or forget to rotate them which can leave us high and dry from time to time. So once we have a charging station that is able to handle all of the batteries at once we will always have our batteries well organized and fully charged. Not to mention that we will only have to have one AC plug coming out of the unit.
I will make sure to post pictures of the charging station once we are done with it. We might also post a parts list and schematic for how to make it.
Unread 19-07-2006, 16:16
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
i would be interested in a scematic and parts list.....so if you ever make one available post it please.
/forest
Unread 21-07-2006, 21:37
The simplest solution is to buy additional connectors of the type you need for the battery, the Anderson 50 amp red. Cut the gator clips off the charger leads, strip back at least 3/4 to 1" of insulation, fold the exposed wire at least twice, and then insert into the Anderson contact. Crimp and solder making sure that there is no exposed wire or whiskers and then insert the contacts into the block. What you have is a mating connector for all batteries (yours and other teams) that is perfectly insulated and easy to use.
Unread 22-07-2006, 15:05
Viper37 Viper37 is offline
AKA: Matt Howard
Viper37 will become famous soon enoughViper37 will become famous soon enough
Send a message via AIM to Viper37
We simply cut the ends off of our charger, crimped on a brand new anderson connector, soldered the contacts, heat shrinked, and voila. They work beautifully.
Unread 23-07-2006, 15:58
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Depending on rules for this coming year this would probably be ok as long as you are sure the charger puts out no more than 6 amps per FIRST's rules.
Why spend all the time and money building something when you could just use a couple store bought chargers and snip off the aligator clips and solder on some anderson quickconnects?
I do not see the purpose as to why you tare apart the charger and replace the charger leads at the charger? There wont be any benefit to adding a larger cable other than if you need to do some weight lifting. The small 18 OR 16 gauge wire is plenty for the little 6AMP charger current.
-Mike
Unread 25-07-2006, 02:13
AKA: Dexter
The main reasons that we want to do this is that we currently have to manually rotate that charger through the batteries that need to be charged which can be a problem since people can forget to do things like that which can leave us with no charged batteries. Second it would reduce the number of cords we have to plug in to power strips because two wall worts and two standerd cables take up too may spots on an power strip. Third because we have to manually check which batteries are charged when people don't label the charged and discharged ones. Fourth because we would like to stay better organized and actually have a designated spot for our batteries rather than throwing them under and table to be pushed around and stepped on when moving around in the pit. Last but not least to give our electrical students something to do.
Unread 25-07-2006, 11:55
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
... we need more of the battery connectors. I know that they are made by Anderson power products ad know that you can get the housings and the contacts at various electrical suppliers...
Although not pre-assembled, for the red Anderson SB50 Connectors, we've had good success with "Helmar Parts," who sells these connectors for about half the price of any of the typical robotics suppliers: http://www.helmarparts.com/product_p/6331g1.htm
Who would have thought that lift trucks would use these connectors?
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 26-07-2006, 12:08
...because we have to manually check which batteries are charged when people don't label the charged and discharged ones.
I don't understand how you intend to address this by building a charging station. You'll still need to check the battery charge somehow if they don't get labeled.
The plastic battery flags (white ones were placed by AndyMark in the 2006 Kit of Parts, and the TechnoKats have given away yellow ones for the past couple of years) work very well for identifying charged batteries. If you put one in the battery connector as you remove it from the charger, you'll always know when a battery needs to be checked and/or charged.
Unread 26-07-2006, 12:37
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Built in battery tester? Thats what our box has. It works great, except the time that the whole box came unplugged, and the batteries just basically died attached to the testers. The lights were lit up, but it wasn't charging.
That required a bit of a modification and now if we lose power, it's not back fed from the battery to the tester light display.
Or that's the plan anyways. I don't know if we did that yet.
As far as acquiring the Anderson doo-hickeys, I remember that Cabela's sold them for a time but can't find them on their site now.
Yes, the same Cabela's that sells Canoes, and hunting equipment among a boat load of other stuff.
Editing Main.c Astronouth7303 Programming 22 20-02-2004 16:45
Main Circuit Breaker Yan Wang Electrical 6 20-02-2003 10:23
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Main Stage archiver 2001 3 24-06-2002 03:06
main driver Kaitlin Palmer Off-Season Events 0 09-04-2002 21:26
