Re: A Swerve Drive Question
Originally Posted by sanddrag
why would you have a swerve (rotating wheel modules) drive with omni wheels? I figured that rotating and moving would involve wheels at awkward angles to each other. The omni wheels would prevent scrubbing (bouncing). Originally Posted by Noah Kleinberg If you rotated the wheels so that diagonal wheels are parallel (like a holonomic drive), then it should be able to rotate and translate simultaneously. I had figured you could just do that, but wondered if there was another way to do it. With a holonomic drive, isn't it best to have the wheels in a perfect square (or diamond)? The wheel modules in a design I've been working on are farther apart. I've been working on a swerve bot for the learning experience and as a cool demonstration robot .Sorry I don't know how to do the quotes Thanks Dan Team 808 |
What is your reason to put omni wheels on a crab/swerve drive? Is it so you can have 100% of your power going toward your direction of travel as opposed to 70% and still be able to rotate while translating? That's the only reasoning I can think of.
They don't have to be in a perfect square, and not being in a square shouldn't make it much less efficient, but it might be harder to program it. See this thread for more: http://www.chiefdelphi.com/forums/sh...ad.php?t=38839. |
| pic: Coaxial Swerve drive, lightened. | CraigHickman | Extra Discussion | 19 | 22-06-2006 15:00 |
| Swerve Drive Whitepapers/Info | Ryan F. | Kit & Additional Hardware | 1 | 20-10-2005 00:51 |
| Swerve Drive on a Jeep | Karthik | Math and Science | 3 | 01-02-2005 17:50 |
| pic: Lego Swerve Drive | CD47-Bot | Robot Showcase | 14 | 26-06-2003 16:19 |
| Swerve Drive | Jeff Waegelin | Technical Discussion | 14 | 17-09-2001 08:06 |
