Go to Post PS. Listen to the wise Brandon Martus. Think before you (re)act. - artdutra04 [more]
Unread 21-07-2006, 00:22
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Vex Transmitter problem
I have got one heck of a strange problem with my Vex transmitter. I programmed a holonomic drive vex robot to use one joystick (channels 1 and 2) to drive it, and for some reason, it switches channel 2 with channel 3 and vice versa. In other words, you have to use the left joystick for moving forward when you should be using channel 2.
I have another transmitter at my house that came with another kit, and when I switched the crystals and used the other transmitter, channel 2 worked just as it should. I went through the first transmitter and set all the configurations to match those on the second, but it still doesn't seem to work. Any help?
Unread 21-07-2006, 01:52
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Vex Transmitter problem
Without seeing your code I'll have to take a SWAG. It sounds like the transmitter is in 23 mode. Try switching it to 12 mode.
Unread 21-07-2006, 02:33
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Did you plot that on a PDOOMA graph?
Matt Krass
Unread 21-07-2006, 17:01
Unregistered User
AKA: Kevin Forbes
I tested that just now and instead of replacing 2 for 3, it caused channel 1 to move all 4 motors.
Here is the code:
#include "UserAPI.h"
int motor1;
int motor2;
int motor3;
int motor4;
int ch1;
int ch2;
void main ( void )
    while ( 1 )
        ch1 = GetRxInput ( 1 , 1 ); //get input from channel 1
        ch2 = GetRxInput ( 1 , 2 ); //get input from channel 2
        motor1 = 255-ch2; //set motor1 opposite from motor2
        motor2 = ch2;
        motor3 = 255-ch1; //set motor3 opposite from motor4
        motor4 = ch1;
        SetPWM ( 1 , motor1 );
        SetPWM ( 2 , motor2 );
        SetPWM ( 3 , motor3 );
        SetPWM ( 4 , motor4 );
It works just fine with the second transmitter and the configurations are the same on both transmitters.
Vex Announcement: FIRST Vex Challenge Extended for 2006-2007 KathieK FIRST Tech Challenge 14 30-07-2006 23:42
transmitter question??? mechanicalbrain Control System 1 23-04-2005 16:55
EDU Demo Code: Serial Data Transmitter Using a State-Machine Kevin Watson Programming 3 28-12-2003 22:56
FM radio transmitter Alexander McGee Electrical 11 29-10-2003 19:41
Need info on how to build temp. receiver and transmitter archiver 1999 5 23-06-2002 22:01
