Go to Post That's some sexy use of aluminium - Bharat Nain [more]
Unread 18-07-2006, 01:46
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Cutting Lexan
What kind of blade do I need to cut lexan and acrylic on a table saw? It doesn't have to be the same blade.
Unread 18-07-2006, 01:55
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Re: Cutting Lexan
Ive always just used a sharp plywood blade. But I am no expert.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 18-07-2006, 02:19
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Cutting Lexan
Note that their is a great difference in how these two materials cut. Lexan will cut without problems with a steel or carbide-tipped rip saw blade. A crosscut saw blade will leave a very wide cutting path. Acrylic is very different, and will shatter if you try to saw it on a table saw. Best to use a band saw or a jigsaw and go slowly.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 18-07-2006, 07:47
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: Cutting Lexan
we found that a table saw ususally chips lexan, but using a band saw slowly, but just fast enough not to melt the lexan is the way to get the cleanest cuts.
Unread 18-07-2006, 09:10
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
Re: Cutting Lexan
Although a band saw would have been my preferred method for cutting acrylic, I have had no problems cutting 1/8" thick stock on a table saw with a carbide blade. The width of the material and the required size of the piece made it necessary to use a table saw. I could also have used a jigsaw for such a large piece, but the table saw assured a straighter cut. Good blade selection is essential to making sure that you get a good cut. Too many teeth on the blade will generate more friction and it may melt. Too few teeth on the blade and the cut will be rough, and in some cases your stock (acrylic) may shatter and chip. Therefore careful and deliberate feeding of the material and an appropriate blade selection will pay off.
Like Gabe says, go slowly to avoid chipping, but also keep the piece moving steadily to avoid heating up the material especially with thicker stock. If you move it too slowly it will tend to heat up, soften, melt and may gum up your blade or even distort along the edge of your cut.
You may also have some success with rotary tools such as a rotozip, Dremel, or a laminate trimmer. And don't forget the old faithful hack saw with. Again be careful about chipping and heating up the material.
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
Unread 18-07-2006, 11:40
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Cutting Lexan
I have had good results using Irwin Marathon blades cutting 1/4" thick acrylic on a table saw. I usually tape both sides with masking tape to help with the chipping problem. In fact, I have had good results cutting just about everything with those Irwin Marathon blades including Lexan and aluminum. We cut about a zillion feet of aluminum this season with one on my 12" miter saw. We also cut a lot of thin (<~1/16" - 1/8") Lexan with a jig/scroll saw and a plain old 7 1/4" skill saw with a plywood blade. You can cut Lexan with just about anything in my experience. At competition, the inspectors wanted us to shield a pinch point/sprocket on our robot and all we had was a small piece of 1/16" Lexan and pair of scissors. The scissors cut it to shape just fine and a couple of minutes and a couple of zip ties later we breezed through inspection.
Unread 18-07-2006, 12:26
FreakyAntelope's Avatar
FreakyAntelope FreakyAntelope is offline
Unregistered User
AKA: Toby Waite
#0246 (Overclocked)
Team Role: Electrical
FreakyAntelope will become famous soon enough
Send a message via AIM to FreakyAntelope
Re: Cutting Lexan
For long straight cuts (like you might need a table saw for), my team has found that it is often easier to snap lexan then to cut it. By using a straight edge and a knife, you can score the lexan, then snap it at the edge of a table, or something else with a sharp corner. For teams with less resources or who don't want students using power tools as often, this is a really simple and effective method, if you're careful when you score it.
For smaller cuts, or curves, we just use our upright band saw, but I've seen teams have a lot of success with a router.
- Toby
Unread 18-07-2006, 19:11
Barry Craig's Avatar
Barry Craig Barry Craig is offline
Crazy Mad Filer
FRC #1852 (Team Amore)
Barry Craig is an unknown quantity at this point
Re: Cutting Lexan
My team used a metal saw.
Barry "Barricus" Craig
Electrical Head/Leadership/Hammer & File Man
Team Amore 1852
"Details, details!"-Mentor Mark Johnson, on everything that we thought was important.
2006 AZ Regional - 8th Place, Highest Rookie Seed Award, Judges Award
Amore Robotics
Unread 20-07-2006, 23:50
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Cutting Lexan
Remember, Lexan is another name for polycarbonate. Acrylic is... another name for acrylic. Polycarb cuts well with a table saw, acrylic does not. Acrylic melts, shatters, etc. Cut it with a bandsaw if you have one.
Unread 21-07-2006, 03:19
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: Cutting Lexan
Acrylic is another name for Plexiglas.*shivers* But I was thinking to get good cuts that are all uniform. But I recently found out that www.pololu.com does laser cutting EXTREMELY cheap so I am going to look into that.
Unread 21-07-2006, 20:23
Re: Cutting Lexan
Just a note... acrylic is the real name for Plexiglass. Just like polycarbonate is the same thing as Lexan. These are just registered names of the same plastic.
But yea. Laser cutting works fine, watercutting is pretty slick too.
I suggest trying EDM too. You'll get interesting results
Unread 24-07-2006, 19:38
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Re: Cutting Lexan
Another great way to cut Lexan is to use either an exact-o knife or a knife that is specially made to cut lexan (Normally you can buy one of these at any local hardware store or atleast one that sells lexan.)
Acrylic as has been crakes very easily. To much vibrations or to much heat when cutting it can cause it to deform. The best way to cut acrylic is to cut it with a hack saw if it is that firm, if its not then i have no idea (I normally break acrylic cause i really have never found a way to cut it good).
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 24-07-2006, 22:29
inphiniti's Avatar
inphiniti inphiniti is offline
AKA: Ron
FRC #1712 (Dawgma)
inphiniti is just really niceinphiniti is just really niceinphiniti is just really niceinphiniti is just really nice
Re: Cutting Lexan
Biting it cuts it quite nicely; unless you can tear it with your bare hands. Note that this method isn't as accurate, but it demonstrates how hard-core you are.
No jk. A table-saw works nicely if you do it slow enough.
Unread 25-07-2006, 18:42
Dick Linn's Avatar
no team (Synergy)
Re: Cutting Lexan
There are inexpensive plastic cutters available, and it would be trivial to make one if you have a grinder or Dremel tool. Here's a picture, though not close up: http://www.pictureframes.com/html/plasticcutter.html and another http://www.dickblick.com/zz574/77/
I've seen them for a couple of bucks on occasion. It's basically a knife blade with a bevel at the tip that is dragged so that it machines out a small curl of plastic as you go. Cut about 1/16" deep and then you just bend the pieces and they break at the line.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 25-07-2006, 19:11
Tim Delles's Avatar
Since 2001.
FRC #0078
Re: Cutting Lexan
Just so you know you should really cut deeper than 1/16". with 1/16" cut myself and other students on our team have found that it is still extermely hard to break the lexan (plus sometimes it doesn't break on the line exactly and you could end with a jagged side) I would recommend going atleast half the distance if not more when cutting it with the knife.
Cutting Lexan dagger Technical Discussion 14 15-02-2006 15:20
Working with Lexan Phil Paspalas Technical Discussion 41 09-02-2006 16:14
pic: Lexan + Heatgun = CD47-Bot Robot Showcase 4 21-02-2004 00:19
Lexan, the wonder material archiver 2001 12 24-06-2002 02:10
lexan bender JamesJones Technical Discussion 9 12-05-2002 18:50
