Go to Post FIRST is inspiration. No matter how you do it, you learn something. Stop being silly. Stop making accusations. Go build robots. Now. - Aignam [more]
Unread 21-07-2006, 13:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Gear alternatives
W.M. Berg has aluminum gears in 16 pitch (and perhaps other sizes) but they'll cost you a bit and take a while to get. What size are you looking for?
Unread 21-07-2006, 13:37
run the trap!!!
Team Role: Human Player
I don't know anything about these. But how strong are composite material gears? They have a steel insert and the gear teeth are made from some sort of plastic.
They look pretty light.
Here are some links:
Gears
Gears
And More Gears
-Philip J. Fry
Unread 22-07-2006, 10:42
UnderDark's Avatar
UnderDark UnderDark is offline
Alumni
AKA: Matthew Korzeniowski
UnderDark will become famous soon enough
I'm no materials engineer, but since the plastic teeth with take most of the pressure of use, I would think that they would be just as strong/weak as fully plastic gears, but will weigh more.
"My gaming is FIRST!"
-Joe Jagadics
"I am like an all powerful warloard"
-Brian Graham
Unread 23-07-2006, 02:27
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Aluminum gears, alloy 2024. If you want, anodize them.
Or just take the gear to a drill press and cut some holes. Dont machine lightening holes... too expensive. Just mark it up using cad, and cut some holes.
3ds max alternatives? Mazin 3D Animation and Competition 24 11-11-2006 19:43
USB-to-Serial Interface Alternatives Josh Adelson FIRST Tech Challenge 8 22-03-2006 09:40
VEX Alternatives... 114gopher FIRST Tech Challenge 3 24-04-2005 20:02
Car Audio on a Cart - Alternatives to Battery Power? DanL Electrical 28 04-02-2004 11:56
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
