Go to Post Eription- the condition of shredding the eardrum from excessive cheering at robot competitions - Wayne C. [more]
Unread 21-07-2006, 19:14
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Need Help Making Part from Spec
I have made this 2 different ways for reference (and no, not in Inventor but in Solidworks).
I'm guessing you made yours the first way I did and that's why you should have 3 sections actually - 2 seams.
Dome one (on left below) uses actual sketch components and tangent relations between them but indeed has 2 seams.
BTW, check your add up on the print of the .885+9.125 = R10.010 (not R10.011).
Or if those are ALL correct, I refer to dome 2.
Dome 2 (on right below) was made using only the origin as the bottom center of the part and using only the dimensions 9.125 and 11.685.
BTW, the green lines are what I actually sketched in and then revolved both of these.
Of course thinking about this more, there is one more possibility. The 1.828 dimension could be the base of the part (straight extrude up) and then a dome could be on top of that with a width of 9.125 and a height of 9.857 (11.685-1.828). Isn't it great to get drawings supplied to you with so many questions involved?? LOL Try accomplishing work in "the real world" under conditions like this, and oh btw throw in already unreachable deadlines while you are at it.
It's fun.. Trust me. I do this every day.
Originally Posted by M. Krass
Also, how do you know this is a dome? The drawing you attached doesn't provide enough information.
Ah, touche'.
LOL I'm guessing he was told it was one, cause that is an awfully weird extruded shape we have here if it's a plate or another type of extruded object.
ID:	4527  Click image for larger version
i need specs for motors and pumps in the kit from last years competition plz help SCYTE16 Motors 3 18-11-2004 22:54
I need help w/ making an Invitational Matt Attallah General Forum 6 14-05-2002 19:48
Need Help, from Mentors for Research Steve Shade General Forum 1 25-02-2002 15:49
Need Help, from high school students for research Steve Shade General Forum 0 24-02-2002 22:18
I need Help from you all. nick reynolds Chit-Chat 18 02-11-2001 23:39
