Go to Post we can crank up the volume and let the world know that we are nerds with a pulse! - dlavery [more]
Unread 21-07-2006, 22:56
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Bluetooth replacement for programming cable?
I am looking for a bluetooth or other wireless device to replace the programming cable for the robot. The only decent modules I can find are form Sparkfun and cost about $60-70 for each end.
I only have $75 for this project and I also need a module for the computer.
If anyone has any ideas please post them.
Thanks,
Eric Haskins KC9JVH
Unread 21-07-2006, 23:34
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Bluetooth replacement for programming cable?
I don't know much about Bluetooth, but I would much rather use an extremely long serial cable (which I do right now ). It is fast, reliable, and proven, unlike Bluetooth serial cables. I think it would be sweet to have such a technology in a perfect world, but not at the price of $70 an end, and certainly not at the cost of reliability and speed.
I don't have any suggestions as to where to go for these ends. I checked on Newegg (http://www.newegg.com) and found one: http://www.newegg.com/Product/Produc...82E16833139008
If you have a Bluetooth-enabled laptop, you probably only need one end, which would meet your budget constraints. If you feel like going through with this, make sure you post the results. There should be no problem with interference--the field runs on 900MHz, and Bluetooth is in the gigahertz range. Also, what about power? Bluetooth devices, I would think, draw a crazy amount of power, and whatever you can fit in that little device probably won't sustain that kind of draw for very long. The one I linked to uses a wall-wart--worse than the serial cable you want to replace.
I don't think that Bluetooth is exactly ideal for our uses. You can decide for yourself. Tell me what you think, and if you do go for it, post what you get.
JBot
Aren't signatures a bit outdated?
Last edited by Madison : 22-07-2006 at 11:56. Reason: Let's try not to be offensive, 'kay?
Unread 22-07-2006, 01:07
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
They have modules that are just bluetooth and may be useable for this but i have no idea where i found them, search these forums someone was planning this out about a year ago and i think the link was on there
KK4KQO
http://voltair.us
Unread 22-07-2006, 06:16
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Awe man...I just visited your link and check that product out, it appears to be a network type blue tooth and not serial, do you have another link for an RS-232 version? I am looking too. And I wondered if anyone else has any feedback for any devices they have tried?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 22-07-2006, 10:41
AKA: Eric Haskins
Thanks everyone. I was hoping someone had found somthing better, but I think the adapter above will work.
Eric Haskins KC9JVH
Unread 22-07-2006, 11:47
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
i dont know if you saw this on the page but
Not mentioned that you need to plug in an AC adapter for this puppy to work.
so you would still need to find a way to power it.
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 22-07-2006, 13:28
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
A quick search on google found this:
http://www.ipenabled.com/bluetooth-rs232-usb.html
I've never used it or seen it in person, but the specs on the web site seem to match what would be required to connect to the RC. You would need to supply 5VDC, which you could pull from an unused PWM port. The data sheet shows 30-50 mA current draw, so a PWM port would be able to handle it.
Unread 23-07-2006, 19:29
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
I am not sure what you mean by "network type blue tooth"...the link I found looks like it is for RS-232...
Unless you just mean wireless serial. Bluetooth can do that, too. I found a product here that looks like it might do what we want. Unfortunately it costs $169 (!! !) The manufacturer claims that the device can draw power from a pin on the serial port--if I'm reading the schematic right, this won't work with the RC as there is no power output. However, we could power this from a PWM output if the current draw is low enough (It isn't listed on the spec sheet for the adapter I just linked to).
The biggest problem is the cost. 2 times $169 equals way too much money...
I will keep searching, but I kinda doubt that there are any really good devices for this out there.
I have never tried one of these devices, or I would link to it. It would be sweet to have that kind of money, but that's probably not going to happen until I get my multi-billion dollar company with a monopoly over the entire software industry going...
Well, it was worth a search...
JBot
Unread 24-07-2006, 03:12
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
This is the one I currently use to do console/serial for a server:
http://www.ipenabled.com/blueportxp.html
Contains a built in battery, and then transmits over Bluetooth.
My Blog!
Unread 24-07-2006, 08:06
This may be fine for debugging, but I wouldn't trust a wireless device to program the robot. Small files over Bluetooth OBEX wouldn't be a problem, but you would need to build another box to catch the files and transport them to the RC. All of this goes without mentioning possible packet loss.
For what its worth, I'd just go pick up a 25 foot serial cable. This is just my opinion though.
Unread 24-07-2006, 10:23
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
I used a Blue Tooth Serial adapter last year and it wasn't good for programming.
It was even slower then a USB to Serial adapter. The only value it had was returning camera values wirelessly.
Unread 24-07-2006, 17:45
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Thanks for telling us this--I won't waste my money on a Bluetooth adapter if the chance comes up.
Darn, that would've been really cool...
JBot
Unread 24-07-2006, 18:58
None #0116
Model number? Vendor?
Unread 26-07-2006, 03:50
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
You might want to try these radio modules instead...
http://www.rentron.com/remote_control/TXLC-434.htm
Edit: I just realized they are only one way communications! Sorry...
Make our own VEX programming cable? Chris_Elston Programming 5 18-04-2006 00:02
Replacement for DHTML editor in version 2? Timothy D. Ginn FIRST-related Organizations 4 07-07-2005 10:43
Bluetooth serial cable replacement seanwitte Technical Discussion 2 13-02-2004 17:25
Custom programming cable thegnome Programming 2 07-02-2004 17:07
Replacement for Bevel Gears? Greg Technical Discussion 3 30-03-2003 19:56
