Go to Post I thanked the tradesmen on our team the same way i do ever year with a handshake and a "thanks for helping us guys", - Mike Schroeder [more]
Unread 21-07-2006, 08:30
Booger's Avatar
Booger Booger is offline
FRC #0637
Booger will become famous soon enough
Gear alternatives
I was looking for lighter gears than the ones i have now. Does anyone know a site that sells spoked gears.
Collars up!
637
Unread 21-07-2006, 11:01
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Gear alternatives
What gears do you have now?
Are you specifically talking about gears, or are you refering to sprockets?
Typically, you won't find a spoked gear until you go to very large toothed gears. Most teams here will lighten the gears themselves by either drilling holes through the bulk of the gear, or turning down the "webbing" of the gear (or both...) If your design does not require a lot of torque, you can use plastic gears, like those from the Fisher Price gearbox. Plastic Gearbox
If you're looking for sprockets that are lighter, you can find aluminum sprockets from both IFI Robotics and AndyMark.
Good Luck,
BEN
Unread 21-07-2006, 13:13
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
And if you are just looking for a light way to transmit power, timing pulleys can also work. (Make sure you figure them out before you use them, they can be tricky.)
Brian Graham
Unread 21-07-2006, 13:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
W.M. Berg has aluminum gears in 16 pitch (and perhaps other sizes) but they'll cost you a bit and take a while to get. What size are you looking for?
Unread 21-07-2006, 13:37
run the trap!!!
Team Role: Human Player
I don't know anything about these. But how strong are composite material gears? They have a steel insert and the gear teeth are made from some sort of plastic.
They look pretty light.
Here are some links:
Gears
Gears
And More Gears
-Philip J. Fry
Unread 22-07-2006, 10:42
UnderDark's Avatar
UnderDark UnderDark is offline
Alumni
AKA: Matthew Korzeniowski
UnderDark will become famous soon enough
I'm no materials engineer, but since the plastic teeth with take most of the pressure of use, I would think that they would be just as strong/weak as fully plastic gears, but will weigh more.
"My gaming is FIRST!"
-Joe Jagadics
"I am like an all powerful warloard"
-Brian Graham
Unread 23-07-2006, 02:27
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Aluminum gears, alloy 2024. If you want, anodize them.
Or just take the gear to a drill press and cut some holes. Dont machine lightening holes... too expensive. Just mark it up using cad, and cut some holes.
3ds max alternatives? Mazin 3D Animation and Competition 24 11-11-2006 19:43
USB-to-Serial Interface Alternatives Josh Adelson FIRST Tech Challenge 8 22-03-2006 09:40
VEX Alternatives... 114gopher FIRST Tech Challenge 3 24-04-2005 20:02
Car Audio on a Cart - Alternatives to Battery Power? DanL Electrical 28 04-02-2004 11:56
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
