Go to Post if you've got the guts you will get the job done. - JamesCH95 [more]
Unread 23-07-2006, 23:29
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
pic: holonomic vex robot
Unread 23-07-2006, 23:34
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: pic: holonomic vex robot
Hey Kevin,
Have you programmed that for full holonomic movement?
EDIT: Didn't see the other wheel. It should be capable for full holonomic movement.
--Matt
Unread 23-07-2006, 23:36
Unregistered User
AKA: Kevin Forbes
its an X the last wheel is hiding in the back somewhere
I did get the programming to work and it drives really well
Unread 23-07-2006, 23:38
Did you have problems with some of the motors being in reverse and therefore putting out slighty different torque?
Unread 23-07-2006, 23:41
Unregistered User
AKA: Kevin Forbes
yep, its too bad the motors go faster one way. I went through and fixed the values so it went as straight as I could get it, and I got it to work with one joystick with one of the transmitters (I have a problem with the other one) so it's easy to control.
Unread 23-07-2006, 23:42
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
This has 4 wheels. You can see all 4. There is one hiding.
EDIT: oops losts of posts in the last few minutes.
Got any video?
Unread 23-07-2006, 23:43
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Originally Posted by JVN
Our experiments also determined that there is NO discernible winding bias on these motors. (The motor runs at about the same speed in FWD and REV).
(Originally posted here.)
Art Dutra IV
世上无难事,只怕有心人.
Unread 23-07-2006, 23:46
Unregistered User
AKA: Kevin Forbes
hmm... Im not so sure if that's true. During a summer vex camp we held at our high school, we had the 4th - 8th graders build the squarebots right out of the book. When they were being driven around, they would veer to one side because one of the motors was flipped over. I'm not sure if they fixed that problem or not, but it is certainly noticeable.
Unread 23-07-2006, 23:51
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Maybe some random coincidence happened where motors on one side were in tolerance going too fast and motors on the other were in tolerance going to slow resulting in twice the error?
Unread 23-07-2006, 23:52
From personal experience I believe that at least some vex motors have a winding bias; however this also could be contributed to differences in motors. I was a programing mentor during a vex robotics camp last week and had huge problems with square bots driving in straight lines during auto periods. I had attributed this to a winding bias (the motors on a square-bot are inverted), because if it were a difference in motor manufacture I should have been able to fix it by adjusting the code. Even with adjusted code I found that battery power played a major role in the difference in motors indicating a winding bias.
Unread 23-07-2006, 23:55
artdutra04's Avatar
How much drifting there is on a Vex robot has a lot more to do with friction in the drivetrain than a discernable motor bias.
If you build the squarebot and you notice that it is always drifting to one side, then one of the sides of the robot has slightly more friction than the other one. If you loosen some of the parts and try to shift some of the pieces around by a few hundredths of an inch you may notice that the drift will disappear.
Art Dutra IV
世上无难事,只怕有心人.
Unread 23-07-2006, 23:58
Actually that makes a lot more sense than a winding bias. To add to that the kids that built that vex bots tighted everying to an extreme. Thanks!
Unread 24-07-2006, 00:02
Unregistered User
AKA: Kevin Forbes
but it has happened with every vex robot I have ever seen or made that had at least one inverted motor. The holonomic robot had 2 pairs of reversed motors, and when driven it would "turn" because 2 of the motors weren't moving as fast. And I do not believe that every robot I have seen had a friction problem on one side.
Unread 24-07-2006, 00:08
Talking Re: pic: holonomic vex robot
Kevin these's a pretty easy way to test this if you've got a spare motor. Just hook it up with an optical shaft encoder and add a gear up and a big wheel to simulate torque on a normal robot. Then run it for 1 min forward and 1 min backward and compare your numbers I would like to see this done.
Unread 24-07-2006, 00:29
Unregistered User
AKA: Kevin Forbes
results in. here's what the shaft encoder read after a minute of full forward and full backward.
Forward: 10339
Backward: 10780
4.5 revolutions more when a motor is spinning backwards then when it is spinning forwards for a minute.
pic: kiwi vex robot colin340 FIRST Tech Challenge 24 01-10-2012 18:57
pic: it's a Vex Holonomic Drive! artdutra04 Robot Showcase 29 01-11-2006 23:08
pic: Vex robot davelu Extra Discussion 7 29-10-2006 20:46
Impossible to truly to vex holonomic with default code? chaoticprout FIRST Tech Challenge 3 08-05-2006 20:40
pic: My vex robot Michael Leicht Extra Discussion 7 19-07-2005 00:59
