Go to Post TL, DR: You may be skilled at karate on your own, but imagine how much better you'll be with Mr. Miyagi mentoring you. - artdutra04 [more]
Unread 24-07-2006, 00:35
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
Re: pic: holonomic vex robot
I dont think its the motors being biased, its probably differences in friction from the motor to the wheels, every robot in vex seems to have the problem, even FIRST robots with 2WD and castors have this problem without any correction.
Unread 24-07-2006, 00:44
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
I didn't have any wheels on the motor. The shaft went straight into the encoder and nothing else. And you do have to remember that they are vex motors, which, I'm sorry to say, aren't the hightest quality motors out there in the market.
EDIT:
I tested 4 more motors using the same program. The motors were consistantly about 3% faster going backwards than forwards.
Motor 1
Forward: 10339
Backward: 10780
Motor 2
Forward: 10136
Backward: 10409
Motor 3
Forward: 9976
Backward: 10269
Motor 4
Forward: 10215
Backward: 10711
Motor 5
Forward: 10070
Backward: 10280
Unread 24-07-2006, 01:27
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Thanks Kevin,
I hope this settles the question of motor biasing. Also any distances counted without wheels will only be increased by added stress on the motor.
Unread 24-07-2006, 14:06
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I was a FLL programmer for three years, and when using lego motors every motor ran at a different speed. I don't think this is something that can be overcome when using DC motors.
I would like to see the code to make that move.
Eric Haskins KC9JVH
pic: kiwi vex robot colin340 FIRST Tech Challenge 24 01-10-2012 18:57
pic: it's a Vex Holonomic Drive! artdutra04 Robot Showcase 29 01-11-2006 23:08
pic: Vex robot davelu Extra Discussion 7 29-10-2006 20:46
Impossible to truly to vex holonomic with default code? chaoticprout FIRST Tech Challenge 3 08-05-2006 20:40
pic: My vex robot Michael Leicht Extra Discussion 7 19-07-2005 00:59
