Go to Post They call us super nerds. I say thank you :D - Gregor [more]
Unread 23-07-2006, 20:30
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Operator Interface Supply Current
I am working on making our operator interfaceportable by put making a a power reg for a 12 volt battery (or whatever else kind of battery I can find for cheap. and I was wondering how much current the operator interface draws at max.
Unread 23-07-2006, 20:55
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Operator Interface Supply Current
the current is not too much of a draw. Also if you look int he white pages there was another team which used 3 or 4 9 volt batteries to power the OI
KK4KQO
http://voltair.us
Unread 23-07-2006, 23:36
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Check on the power brick for the OI we received in the kit, somewhere on it should list the max current output. It doesn't draw more than that.
Matt Krass
Unread 24-07-2006, 15:33
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
I just got done reading through the white paper. I don't really understand why they used 3 9 volt batteries.
I thought you could only input 5 volts. But I guess you can input anything?
Also what about a voltage regulator?
Unread 24-07-2006, 15:44
Matt Krass's Avatar
AKA: Dark Ages
Depending on how they're wired that can be a combined 27 volts or a combined 9 volts. Combining all three to get 9 volts approximately triples the lifetime of the battery set. I believe (I am not certain though) the OI takes anything up to 12V, in fact 5V may not be enough to power the radio modem as well.
Matt Krass
Unread 24-07-2006, 16:00
The OI requires 9 volts.
It will draw up to 1.5amps.
Be very, very careful of the polarity of the power connector. You run the risk of damaging your OI if you do it wrong.
Here are the ratings from the OI's AC adaptor and the polarity of the connector.
Name:	OI Power.jpg
Unread 24-07-2006, 16:46
The OI can draw up to 1500 milliamps. A standard 9v battery is good for about 500 milliamp-hours, which would be drained in as little as 20 minutes. Using three 9 volt batteries in parallel gives at least an hour of useful power.
You're only "authorized" to give it 9 volts, but it runs fine on 12 (which I think is what gets supplied when it's tethered).
The OI has one built in. I'm pretty sure it runs on five volts internally, which would normally require at least seven volts of input to keep well regulated.
Unread 24-07-2006, 16:47
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Ohh.......I didn't have the wall thing, and assumed it was 5 volts. That makes sense now.
Well that all makes this a TON easier.
It's just kinda sad that I randomly have all the parts in my basement.
operator interface tml240 Electrical 5 10-02-2004 17:50
operator interface power supply hi_im_sean General Forum 1 05-02-2003 14:50
Operator Interface Heads Up Madison Robotics Education and Curriculum 6 11-12-2002 06:59
operator interface board archiver 2001 4 24-06-2002 00:33
Operator Interface Improvements Dan Technical Discussion 3 18-02-2002 19:23
